* | 2009-09-09 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-09-09 | 1 | -0/+40 |
| | | | | | | * startup/bspstart.c: Added dummy implementation of firmware syscalls for use with QEMU. Dummy handler is installed if no pre-existing firmware handler is found. | ||||
* | Try enabling the data cache. | Eric Norum | 2009-07-30 | 1 | -5/+4 |
* | PR 1420/bsps | Eric Norum | 2009-07-28 | 1 | -1/+6 |
| | | | | | | Turn on buffered writes to DRAM. As Device Errata SECF124 notes this may cause double writes, but that's not really a big problem and benchmarking tests have shown that buffered writes do gain some performance. | ||||
* | As per Freescale chip errata, disable buffered writes. | Eric Norum | 2009-06-02 | 1 | -3/+15 |
* | Back out changes from 2008-05-16 -- they don't seem to work. | Eric Norum | 2008-05-19 | 1 | -4/+24 |
* | Use shared version of bootstrap to set up workspace. | Eric Norum | 2008-05-16 | 1 | -24/+4 |
* | 2008-05-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-05-12 | 1 | -1/+0 |
| | | | | | | | | | | | | * startup/bspstart.c: Refactored and renamed initialization routines to rtems_initialize_data_structures, rtems_initialize_before_drivers, rtems_initialize_device_drivers, and rtems_initialize_start_multitasking. This opened the sequence up so that bootcard() could provide a more robust and flexible framework which is easier to explain and understand. This also lays the groundwork for sharing the division of available memory between the RTEMS workspace and heap and the C library initialization across all BSPs. | ||||
* | More clean up of FPGA interrupts. | Eric Norum | 2008-04-24 | 1 | -2/+1 |
* | startup/bspstart.c: Clean up non-FPGA use of EPORT interrupts. | Eric Norum | 2008-04-08 | 1 | -11/+3 |
| | | | | network/network.c: Track half/full-duplex changes from 4.7 branch. | ||||
* | 2007-12-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-11 | 1 | -9/+1 |
| | | | | | | * clock/clock.c, include/bsp.h, startup/bspstart.c: Eliminate copies of the Configuration Table. Use the RTEMS provided accessor macros to obtain configuration fields. | ||||
* | 2007-12-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-04 | 1 | -6/+0 |
| | | | | | | * Makefile.am, startup/bspstart.c: Move interrupt_stack_size field from CPU Table to Configuration Table. Eliminate CPU Table from all ports. Delete references to CPU Table in all forms. | ||||
* | 2007-12-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-03 | 1 | -6/+0 |
| | | | | | | | | | | * include/bsp.h, startup/bspstart.c: Moved most of the remaining CPU Table fields to the Configuration Table. This included pretasking_hook, predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace, extra_mpci_receive_server_stack, stack_allocate_hook, and stack_free_hook. As a side-effect of this effort some multiprocessing code was made conditional and some style clean up occurred. | ||||
* | 2007-11-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-11-26 | 1 | -199/+202 |
| | | | | | * startup/bspstart.c: Eliminate the interrupt_vector_table field in the m68k CPU Table since it is never read. | ||||
* | 2007-03-12 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-03-12 | 1 | -1/+1 |
| | | | | | | | | | * clock/clock.c, console/console.c, include/bsp.h, include/coverhd.h, include/tm27.h, network/network.c, start/start.S, startup/bspclean.c, startup/bspstart.c, startup/init5282.c, startup/linkcmds, timer/timer.c: Correct license URL and/or fix mistake in copyright notice. Both of these mistakes appear to be from code submitted after these changes were made previously. | ||||
* | 2007-03-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-03-11 | 1 | -3/+2 |
| | | | | | | * startup/bspstart.c: Remove assignments of Cpu_table.do_zero_of_workspace to TRUE since TRUE is the default value in boot_card.c | ||||
* | * startup/bspstart.c: Changed BSP_installVME_isr() so that | Till Straumann | 2006-12-15 | 1 | -69/+138 |
| | | | | | | | | | | | | the special handling of a 'FPGA interrupt' [this FPGA is *not* present on the uC5282 module but is externally connected to IRQ1 on Eric Norum's particular 'motherboard'] is only activated when connecting to the special vectors > 192. The change allows us ordinary users [:-)] to use IRQ1 normally, simply by connecting an ISR to vector 64+1... Also, BSP_enable_irq_at_pic(), BSP_disable_irq_at_pic(), BSP_irq_is_enabled_at_pic() were introduced (compat. with some PPC BSPs). | ||||
* | Add bsp_setbenv system call. | Eric Norum | 2006-08-01 | 1 | -1/+2 |
* | Allow single spurious FPGA interrupt. | Eric Norum | 2006-05-15 | 1 | -3/+8 |
* | Improve handling of unexpected FPGA interrupt conditions. | Eric Norum | 2006-05-15 | 1 | -3/+19 |
* | Add default exception handler. | Eric Norum | 2006-04-11 | 1 | -0/+52 |
* | Add missing reset cause bit. | Eric Norum | 2006-03-24 | 1 | -0/+1 |
* | Avoid possible division by zero. | Eric Norum | 2006-02-06 | 1 | -1/+1 |
* | Add code to maintain CPU load average. | Eric Norum | 2006-01-29 | 1 | -1/+4 |
* | Add another 'extended BSP' routine which returns reboot status register ↵ | Eric Norum | 2005-12-19 | 1 | -0/+37 |
| | | | | information | ||||
* | Assign copyright to OAR since all files descend from OAR's source. | Eric Norum | 2005-11-07 | 1 | -6/+2 |
* | Add bsp_reset bootrom call. | Eric Norum | 2005-09-16 | 1 | -0/+1 |
| | | | | Call bsp_reset from bsp_cleanup(). | ||||
* | Enable CS1* and CS2* now that Arcturus bootstrap PROMs no longer take care ↵ | Eric Norum | 2005-07-06 | 1 | -0/+1 |
| | | | | of that for us. | ||||
* | Try to maintain compatability with everyone else's VBR changes. | Eric Norum | 2005-05-24 | 1 | -5/+0 |
* | Followup fix to Joel's earlier _VBR changes. | Eric Norum | 2005-05-11 | 1 | -0/+5 |
* | Try insructioin-only cache. | Eric Norum | 2005-04-21 | 1 | -7/+19 |
* | Expose some read/write copies of configuration registers. | Eric Norum | 2005-04-19 | 1 | -22/+25 |
* | Set up IRQ1* handling properly. | Eric Norum | 2005-04-10 | 1 | -10/+11 |
* | FPGA interrupt status register is now 16-bit. | Eric Norum | 2005-04-09 | 1 | -3/+56 |
* | Add NOP after writing the CACR is there to address the issue | Eric Norum | 2005-03-10 | 1 | -1/+24 |
| | | | | noted in "Device Errata MCF5282DE", Rev. 1.7, 09/2004. | ||||
* | Remove some now-unused declarations. | Eric Norum | 2005-02-14 | 1 | -1/+0 |
* | Don't cache flash. | Eric Norum | 2005-02-14 | 1 | -5/+1 |
* | Rearrange devLib address spaces. | Eric Norum | 2005-02-12 | 1 | -2/+2 |
* | Add some more system calls. | Eric Norum | 2005-02-12 | 1 | -9/+30 |
| | | | | Improve in-line assembly. | ||||
* | Name changes. | Eric Norum | 2005-02-10 | 1 | -3/+20 |
| | | | | Add some more system calls. | ||||
* | Intra-level priorities range from 0 to 7. | Eric Norum | 2005-02-08 | 1 | -1/+1 |
| | | | | Levels range from 1 to 6. | ||||
* | Ensure consistency of 'installed' bitmap. | Eric Norum | 2005-02-08 | 1 | -1/+5 |
* | Set INTC0_ICRx registers properly. | Eric Norum | 2005-02-07 | 1 | -1/+1 |
* | Clean up the RAM/FLASH sizes/locations are specified. | Eric Norum | 2005-02-05 | 1 | -17/+9 |
* | Fix flash base address. | Eric Norum | 2005-02-04 | 1 | -1/+1 |
| | | | | Enable UART2. | ||||
* | Clean up INTC0 initialization. EPORT1-7 sources are fixed level/priority. | Eric Norum | 2005-02-04 | 1 | -14/+25 |
* | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 1 | -4/+4 |
| | | | | | * console/console.c, include/bsp.h, network/network.c, startup/bspstart.c: Remove obsolete fixed size types. | ||||
* | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 1 | -1/+1 |
| | | | | | * startup/bspstart.c: rtems_interrupt_catch(trampoline, vector, &old_handler). | ||||
* | Add 'extended' BSP support (pseudo-VME) | Eric Norum | 2005-02-03 | 1 | -6/+109 |
* | Add support for interrupt controller allocation. This will provides a | Eric Norum | 2005-02-03 | 1 | -1/+21 |
| | | | | mechanism for applications to find a free level/priority. | ||||
* | Clean up bootloader syscall handling. | Eric Norum | 2005-02-02 | 1 | -25/+25 |
