* start/reset.S: Remove cat(). Add EXPAND(). Make EXCEPTION_HANDLER
ANSI-C compliant.
* Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am
start/Makefile.am, startup/Makefile.am, timer/Makefile.am
wrapup/Makefile.am.
Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Remove.
* Makefile.am: Remove non-existing times from EXTRA_DIST.
* start/Makefile.am: Remove non-existing cpuboot.c from EXTRA_DIST.
* wrapup/Makefile.am: Reflect changes to libcpu.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* start/debugreset.S, start/reset.S: Removed incorrect statement about
copyright assignment.
PR414 - Fixed the global interupt vector register.
Linker command file to have the boot code in the first 8K.
The chip select remap needed to be volatile.
* start/Makefile.am: Pick up rest of Ralf'f changes and use
cp not make-rel since there is no point in this case.
* start/debugreset.S: Rights were not assigned.
* start/reset.S: Add ifdef to avoid core dump until Chris can
track it down.
* start/cpuboot.c: Moved to startup.
* startup/Makefile.am: Account for above.
* start/Makefile.am: Fix bug in previous patch.
Really add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o.
This was tracked as PR39.
* include/bsp.h, start/cpuboot.c, start/reset.S, startup/debugger,
startup/linkcmds, startup/rom: Eliminated required definition of
macros in the custom file for the BSP to compile. The ROM and ROM
address and size settings are now linker script items.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include
compile.am
./bootstrap
converted to automake.
that converts the libbsp/i386 subdirectory to full automake.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
which fixes a couple of bugs in RTEMS's old style Makefile.ins, which
apparently were introduced by moving the start directories and not
having adapted the Makefile.ins.
patch -p1 < rtems-rc-19991203-10.diff
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
