* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, include/bsp.h: Review of all bsp_cleanup()
implementations. In this phase, all prototypes were removed from
bsp.h and empty implementations were removed and made to use the
shared stub.
* startup/bspclean.c: Removed.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate copies
of the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* include/bsp.h: New header guard.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c,
c/src/lib/libbsp/m68k/ods68302/include/bsp.h,
c/src/lib/libbsp/m68k/ods68302/startup/cpuboot.c,
c/src/lib/libbsp/m68k/ods68302/startup/crc.c,
c/src/lib/libbsp/m68k/ods68302/startup/gdb-hooks.c,
c/src/lib/libbsp/m68k/ods68302/startup/m68302scc.c,
c/src/lib/libbsp/m68k/ods68302/timer/timer.c: Include
<rtems/m68k/m68302.h> instead of <m68302.h>.
* clock/ckinit.c, include/bare.h, include/bsp.h, include/crc.h,
startup/bspstart.c, startup/cpuboot.c, startup/crc.c,
startup/gdb-hooks.c, startup/m68302scc.c, timer/timer.c: Convert to
using c99 fixed size types.
* include/bsp.h: Replace stringification madness to pick up bare.h
(Doesn't work with gcc >= 3.3) with a somewhat cleaner madness.
Reflect changes to bsp.am.
startup/bspclean.c, startup/bspstart.c, timer/timer.c: URL for
license changed.
* startup/Makefile.am: Remove -DGDB_MONITOR_ACTIVE (Not used
anywhere).
Add ODS60302_DEBUG conditional.
* include/bsp.h: Fix broken bsp_cat macros (Not compliant to gcc31).
* configure.ac: Add --enable-ods60302-debug.
This was tracked as PR39.
* include/bsp.h, start/cpuboot.c, start/reset.S, startup/debugger,
startup/linkcmds, startup/rom: Eliminated required definition of
macros in the custom file for the BSP to compile. The ROM and ROM
address and size settings are now linker script items.
* include/Makefile.am: Fixed typo.
converted to automake.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
