path: root/c/src/lib/libbsp/m68k/mrm332/misc/dotests (unfollow)
2018-04-26bsps: Move documentation, etc. files to bspsSebastian Huber1-12/+0
This patch is a part of the BSP source reorganization. Update #3285.
2012-05-11Remove CVS Id Strings (manual edits after script)Joel Sherrill1-3/+0
These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns.
2001-05-252000-05-25 Matt Cross <profesor@gweep.net>Joel Sherrill1-0/+0
* New MRM332 BSP for the Mini RoboMind board based on the 68332 microcontroller designed and build by Mark Castelluccio. For details on the MRM see http://www.robominds.com. * .cvsignore, ChangeLog Makefile.am, README, bsp_specs, clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in, console/.cvsignore, console/Makefile.am, console/console.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c, spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c, start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore, startup/Makefile.am, startup/bspclean.c, startup/bspstart.c, startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM, timer/.cvsignore, timer/Makefile.am, timer/timer.c, times, wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
2000-06-12Merged from 4.5.0-beta3aJoel Sherrill1-7/+7
1997-03-11updates from John GwynneJoel Sherrill1-0/+15
