Update #2408.
do
echo $b
# echo $g
-i $b
done
These header files were only used by one BSP and they are
hardware dependent. The hardware dependency always made
them bad candidates for where they were in the tree. But
this fixes that.
and clean up
output.
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Conflicts:
for details.
* console/mc68ec.c:
* timer/timer.c: Include <rtems/btimer.h>.
* timer/timer.c: Remove warnings.
* console/leds.c, timer/timer.c: Remove warnings.
* make/custom/idp.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/idp.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* timer/timer.c: Eliminate uses of old benchmark timer names.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
