* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* Per PR260 eliminate use of make-target-options. This impacted
RTEMS allowing a distinction between the CPU32 and CPU32+ in the
SuperCore and required that the m68k optimized memcpy be moved
to libcpu.
* wrapup/Makefile.am: Pick up memcpy.o from libcpu.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* configure.in: Remove.
* network/network.c: Removed unused variable warnings.
* Makefile.am, configure.in, include/Makefile.am,
wrapup/Makefile.am: Updated to reflect addition of network driver
by Franck Julien <FranckJ@cxr.fr>.
* include/m302_int.h, network/.cvsignore, network/Makefile.am,
network/network.c: New file.
* startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and
* clock/ckinit.c: Do not just set the IMR, OR the enable bit in.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include
compile.am
that contains:
* Removes MKLIB
handling)
./bootstrap
converted to automake.
and memory layout. Next step is to share the same bsp_pretasking_hook.
for the gen68360 that let it work with ELF and C++ exceptions. This
was used as the basis for changes to EVERY m68k bsp_specs and linkcmds.
Before this modification is over, the layout of the starting stack,
heap, and workspace will likely be modified for every m68k BSP. Then
they will all be very similar.
that converts the libbsp/i386 subdirectory to full automake.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
which fixes a couple of bugs in RTEMS's old style Makefile.ins, which
apparently were introduced by moving the start directories and not
having adapted the Makefile.ins.
patch -p1 < rtems-rc-19991203-10.diff
Addtional major bugs:
work with m68k-elf on late model versions of binutils (990901+)
without overlapping or missing section errors.
dependencies of "Makefile".
--enable-maintainer-mode.
