Reflect changes to bsp.am.
spurious/spinit.c, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, startup/vmeintr.c, timer/timer.c, timer/timerisr.S:
URL for license changed.
spurious/Makefile.am: Reflect having moved automake.
* spurious/Makefile.am: Remove AUTOMAKE_OPTIONS.
converted to automake.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
both ports.
to lib/include.
be resolved.
like signal dispatching.
IDLE task priority changed from 0 to 255 during initialization.
