* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 1 | -0/+4 |
| | | | | * Makefile.am: Reflect having moved aclocal/. | ||||
* | Fix broken ChangeLog entries. | Ralf Corsepius | 2003-08-18 | 1 | -1/+1 |
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 1 | -0/+4 |
| | | | | Makefile.am: Reflect having moved automake. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 1 | -0/+4 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 1 | -0/+4 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 1 | -0/+4 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-06 | 1 | -0/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_BSP_CACHE. | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 1 | -0/+6 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-06-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-06-27 | 1 | -0/+6 |
| | | | | | | * Thomas Doerfler <Thomas.Doerfler@imd-systems.de> added m68k support to the shared gdb stub glue thus adding a directory. * configure.ac: Modified to reflect above. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -0/+7 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-10-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-10-26 | 1 | -0/+4 |
| | | | | * acinclude.m4: Added mcf5206elite. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 1 | -0/+6 |
| | | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | ||||
* | 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-10 | 1 | -0/+5 |
| | | | | | * acinclude.m4: New file. * configure.in: Use RTEMS_BSP_SUBDIR. | ||||
* | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-09 | 1 | -0/+4 |
| | | | | * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | ||||
* | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-02 | 1 | -0/+4 |
| | | | | * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | ||||
* | 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-27 | 1 | -0/+5 |
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. | ||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-10 | 1 | -0/+3 |
