Add doxygen to the header files in the /lm32/milymist/include directory.
Add doxygen to the header files in the /lm32/lm32_evr/include directory.
TOD_MILLISECONDS_TO_TICKS().
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
Use <bsp/bootcard.h> to get prototype for bsp_cleanup(). Fix
bsp_cleanup() definition if necessary.
Add and use rtems_blkdev_request_done(). Block device transfer requests
must signal the completion status now with rtems_blkdev_request_done().
The return value of the block device IO control will be ignored for
transfer requests.
The first parameter of rtems_blkdev_request_cb is now the transfer
request structure.
Renamed rtems_blkdev_request::req_done to rtems_blkdev_request::done to
break third party drivers at compile time, otherwise this API change
would result in runtime errors.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Conflicts:
Leave the task of providing a suitable firmware for the Milkymist softusb
core to the application instead of having an inflexible array in the driver.
Signed-off-by: Gedare Bloom <gedare@rtems.org>
Slightly adjust video timing registers since we had problems with a few screens and the previous values.
Forward MIDI messages from the softusb controller to the application.
We increased PMEM to 8 kB but never updated SOFTUSB_PMEM_SIZE.
This didn't have much of an effect because all we used it for was
to zero unused program memory - which we should never touch
anyway.
But now that "usb load" in FN uses SOFTUSB_PMEM_SIZE, this caused
it to silently truncate the firmware, producing rather puzzling
effects.
Signed-off-by: Joel Sherrill <joel.sherrill@oarcorp.com>
* ChangeLog: Add PR number to ChangeLog entry
* milkymist_midi/midi.c: move MIDI message detection from higher layers
to the MIDI interrupt handler
PR 1972/bsps
* milkymist_video/milkymist_video.h, milkymist_video/video.c: Adds an
ioctl to implement selection of composite on any connector, S-Video
and Component sources on the Milkymist One.
PR 1970/bsps
* milkymist_clock/ckinit.c, milkymist_console/console.c,
milkymist_console/uart.c, milkymist_timer/timer.c: Support for the
new Milkymist sysctl and clock frequency detection.
PR 1970/bsps
* include/system_conf.h: Support for the new Milkymist sysctl and clock
PR 1966/bsps
* milkymist_console/console.c, milkymist_console/uart.c,
milkymist_console/uart.h, milkymist_midi/midi.c: support for the new
UART core and interrupt map
PR 1966/bsps
* include/system_conf.h: support for the new UART core and interrupt
map
PR 1869/bsps
* ChangeLog: Spacing.
* README: Removed.
PR 1869/bsps
* milkymist_networking/mm_crc32.c: Removed.
PR 1869/bsps
* README: Merge content from lm32/README which was specific to
this BSP.
PR 1869/bsps
* startup/bspclean.c: New file.
* include/tm27.h: Removed.
* ChangeLog, Makefile.am, README, preinstall.am, include/bsp.h,
include/system_conf.h, make/custom/milkymist.cfg, startup/linkcmds:
Complete BSP for Milkymist One supporting Milkymist SOC 1.0.x.
Includes new or updated drivers for:
- Multi-standard video input (PAL/SECAM/NTSC)
- Two DMX512 (RS485) ports
- MIDI IN and MIDI OUT ports
- VGA output
- AC'97 audio
- NOR flash
- 10/100 Ethernet
- Memory card (experimental and incomplete)
- USB host connectors (input devices only)
- RC5 infrared receiver
- RS232 debug port
* shared/milkymist_networking/network.c:
* shared/milkymist_timer/timer.c, shared/timer/timer.c:
Include <rtems/btimer.h>.
* .cvsignore: New file.
* shared/milkymist_ac97/ac97.c, shared/milkymist_clock/ckinit.c,
shared/milkymist_clock/clock.h, shared/milkymist_console/console.c,
shared/milkymist_console/uart.c, shared/milkymist_console/uart.h,
shared/milkymist_framebuffer/framebuffer.c,
shared/milkymist_gpio/gpio.c, shared/milkymist_networking/mm_crc32.c,
shared/milkymist_networking/network.c,
shared/milkymist_networking/network.h,
shared/milkymist_timer/timer.c: New files.
* acinclude.m4, configure.ac: Add Milkymist BSP developed as part of
GSOC 2010.
