output.
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Add doxygen to the header files in the /lm32/milymist/include directory.
Add doxygen to the header files in the /lm32/lm32_evr/include directory.
TOD_MILLISECONDS_TO_TICKS().
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
Use <bsp/bootcard.h> to get prototype for bsp_cleanup(). Fix
bsp_cleanup() definition if necessary.
Add and use rtems_blkdev_request_done(). Block device transfer requests
must signal the completion status now with rtems_blkdev_request_done().
The return value of the block device IO control will be ignored for
transfer requests.
The first parameter of rtems_blkdev_request_cb is now the transfer
request structure.
Renamed rtems_blkdev_request::req_done to rtems_blkdev_request::done to
break third party drivers at compile time, otherwise this API change
would result in runtime errors.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Conflicts:
Leave the task of providing a suitable firmware for the Milkymist softusb
core to the application instead of having an inflexible array in the driver.
Signed-off-by: Gedare Bloom <gedare@rtems.org>
Slightly adjust video timing registers since we had problems with a few screens and the previous values.
Forward MIDI messages from the softusb controller to the application.
We increased PMEM to 8 kB but never updated SOFTUSB_PMEM_SIZE.
This didn't have much of an effect because all we used it for was
to zero unused program memory - which we should never touch
anyway.
But now that "usb load" in FN uses SOFTUSB_PMEM_SIZE, this caused
it to silently truncate the firmware, producing rather puzzling
effects.
Signed-off-by: Joel Sherrill <joel.sherrill@oarcorp.com>
* ChangeLog: Add PR number to ChangeLog entry
* milkymist_midi/midi.c: move MIDI message detection from higher layers
to the MIDI interrupt handler
PR 1972/bsps
* milkymist_video/milkymist_video.h, milkymist_video/video.c: Adds an
ioctl to implement selection of composite on any connector, S-Video
and Component sources on the Milkymist One.
PR 1970/bsps
* milkymist_clock/ckinit.c, milkymist_console/console.c,
milkymist_console/uart.c, milkymist_timer/timer.c: Support for the
new Milkymist sysctl and clock frequency detection.
PR 1970/bsps
* include/system_conf.h: Support for the new Milkymist sysctl and clock
PR 1966/bsps
* milkymist_console/console.c, milkymist_console/uart.c,
milkymist_console/uart.h, milkymist_midi/midi.c: support for the new
UART core and interrupt map
