Lay groundwork for a simulator configuration configuration
for the Milkymist. This is needed to use the shared code.
output.
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Add doxygen to the header files in the /lm32/milymist/include directory.
Add doxygen to the header files in the /lm32/lm32_evr/include directory.
TOD_MILLISECONDS_TO_TICKS().
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
Use <bsp/bootcard.h> to get prototype for bsp_cleanup(). Fix
bsp_cleanup() definition if necessary.
Add and use rtems_blkdev_request_done(). Block device transfer requests
must signal the completion status now with rtems_blkdev_request_done().
The return value of the block device IO control will be ignored for
transfer requests.
The first parameter of rtems_blkdev_request_cb is now the transfer
request structure.
Renamed rtems_blkdev_request::req_done to rtems_blkdev_request::done to
break third party drivers at compile time, otherwise this API change
would result in runtime errors.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Conflicts:
Leave the task of providing a suitable firmware for the Milkymist softusb
core to the application instead of having an inflexible array in the driver.
Signed-off-by: Gedare Bloom <gedare@rtems.org>
Slightly adjust video timing registers since we had problems with a few screens and the previous values.
Forward MIDI messages from the softusb controller to the application.
We increased PMEM to 8 kB but never updated SOFTUSB_PMEM_SIZE.
This didn't have much of an effect because all we used it for was
to zero unused program memory - which we should never touch
anyway.
But now that "usb load" in FN uses SOFTUSB_PMEM_SIZE, this caused
it to silently truncate the firmware, producing rather puzzling
effects.
Signed-off-by: Joel Sherrill <joel.sherrill@oarcorp.com>
* ChangeLog: Add PR number to ChangeLog entry
* milkymist_midi/midi.c: move MIDI message detection from higher layers
to the MIDI interrupt handler
