* | Patch rtems-rc-20000104-6.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-10 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | | that converts the i960 directory to automake. The same kind of libbsp configuration as for the mips64orion, now for the i960. In addition to libbsp configuration this patch also contains two fixes for cvme961.cfg and rxgen960.cfg, which contained non-functional make-exes. (Now both bsps probably have the same issues with linking c++ applications as the gensh2 has, but this is a different open issue not tried to be solved now). The rxgen961 also seems to have problems with its start file, because linking apps fails due to not finding start.o. (Note that libbsp/i960/rxgen960 lacks a start subdirectory!). I leave solving this issue to you :) | ||||
* | Patch rtems-rc-19991117-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-22 | 1 | -3/+3 |
| | | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib." | ||||
* | Last cleanup to attempt to link. | Joel Sherrill | 1999-10-27 | 2 | -1/+3 |
* | rxgen960 now compiles -- may not link. | Joel Sherrill | 1999-10-27 | 5 | -17/+17 |
* | Added CVS Ids and a basic header. More header cleanup needed. | Joel Sherrill | 1999-10-27 | 41 | -8/+168 |
* | Removed systbl.S save_systbl.c. They were unnecessary. | Joel Sherrill | 1999-10-27 | 3 | -523/+2 |
* | Removed sctns.S. This file was obviously the output of the compiler. | Joel Sherrill | 1999-10-27 | 2 | -336/+1 |
* | Replaced Makefile.in's with modified copies of cvme961 to get | Joel Sherrill | 1999-10-27 | 1 | -41/+39 |
| | | | | autoconf/automake changes. | ||||
* | Moved systbl.s to systbl.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved sctns.s to sctns.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved rxgen_romld.s to rxgen_romld.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved ihandler.s to ihandler.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved asmstub.s to asmstub.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved asmfault.s to asmfault.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson | Joel Sherrill | 1999-10-27 | 48 | -0/+4614 |
<mark@ramix.com> of RAMIX. |
