Reflect changes to bsp.am.
* bsp_specs: Remove *lib:.
* console/console-io.c, include/bsp.h, startup/bspstart.c: URL for
license changed.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* wrapup/Makefile.am: Add $(LIB) to all-local.
* timer: New subdirectory.
* timer/Makefile.am: New file.
* timer/.cvsignore: New file.
* Makefile.am: Modified to reflect above.
* configure.ac: Ditto.
* include/bsp.h: Stubs to let tm27 compile and link.
* console/console-io.c: Fixed typo.
* configure.in: Remove.
* console/console-io.c: Added console_initialize_hardware().
* console/Makefile.am, start/Makefile.am, startup/Makefile.am,
wrapup/Makefile.am, clock/Makefile.am: Include compile.am
