* console/console-io.c: Added console_initialize_hardware().
* console/Makefile.am, start/Makefile.am, startup/Makefile.am,
wrapup/Makefile.am, clock/Makefile.am: Include compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
are now in libcpu. This required significant rework of the
score/cpu header files and the creation of multiple header files
and subdirectories in libcpu/i960.
have them.
from cvs by adding .cvsignore files.
by gdb 5.0's i960 simulator) is enough to run hello world.
