Since the per-CPU SMP lock must be acquired and released to send the
message a single interrupt broadcast operations offers no benefits. If
synchronization is required, then a SMP barrier must be used anyway.
Rename bsp_smp_initialize() into _CPU_SMP_Initialize() since every CPU
port must supply this function.
Interrupt support for SMP and the per-CPU thread dispatch disable level.
The commit partially restores the _ISR_Handler code to the original
version in commit b8fc2de1ce089c585da81c157ec0f24a90e484b7. A list of
reverted changes follows.
commit c236082873cb4a2fd42af4ca0868106e1dd65422
Author: Sebastian Huber <sebastian.huber@embedded-brains.de>
Date: Tue Jul 30 15:54:53 2013 +0200
smp: Provide cache optimized Per_CPU_Control
Delete _Per_CPU_Information_p.
This commit was completely reverted.
commit 39e51758c86754cef5ba4521c0c36578521f73d0
Date: Fri Jun 14 14:00:38 2013 +0200
smp: Add and use _CPU_SMP_Get_current_processor()
Add and use _SMP_Get_current_processor() and
rtems_smp_get_current_processor().
Delete bsp_smp_interrupt_cpu().
Change type of current processor index from int to uint32_t to match
_SMP_Processor_count type.
commit e94aa61b6820e34732840139dbe3f2016c6f1e24
Author: Till Straumann <strauman@slac.stanford.edu>
Date: Fri Aug 5 00:15:50 2011 +0000
2011-08-04 Till Straumann <strauman@slac.stanford.edu>
* shared/irq/irq_asm.S: BUGFIX (introduced by SMP changes
which moved code around, apparently): *must* store i8259
mask to frame *before* switching to IRQ stack. The code
retrieves the mask after switching back to original stack.
Also, the IRQ stack has no reserved space for the mask;
storing it there could overwrite memory!
commit 01f2692e338d592f363b2e27b2f62d8182d1124e
Author: Jennifer Averett <Jennifer.Averett@OARcorp.com>
Date: Mon Aug 1 13:41:50 2011 +0000
2011-08-01 Jennifer Averett <Jennifer.Averett@OARcorp.com>
PR 1802
* shared/irq/irq_asm.S, shared/irq/irq_init.c, shared/smp/smp-imps.c,
shared/smp/smp-imps.h: Add SMP support for i386.
* shared/smp/getcpuid.c: New file.
The parts modifying the code of _ISR_Handler were reverted.
commit 66729db3115e865fa45bc4e9ab81d8266894151c
Author: Joel Sherrill <joel.sherrill@OARcorp.com>
Date: Wed Mar 16 20:05:17 2011 +0000
2011-03-16 Jennifer Averett <jennifer.averett@OARcorp.com>
PR 1729/cpukit
* shared/irq/irq_asm.S: Add next step in SMP support. This adds an
allocated array of the Per_CPU structures to support multiple cpus vs
a single instance of the structure which is still used if SMP support
is disabled. Configuration support is also added to explicitly enable
or disable SMP. But SMP can only be enabled for the CPUs which will
support it initially -- SPARC and i386. With the stub BSP support, a
BSP can be run as a single core SMP system from an RTEMS data
structure standpoint.
Add and use _Per_CPU_Get_by_index() and _Per_CPU_Get_index(). Add
_Per_CPU_Send_interrupt(). This avoids direct access of
_Per_CPU_Information.
Delete bsp_smp_wait_for(). Other parts of the system work without
timeout, e.g. the spinlocks. Using a timeout here does not make the
system more robust.
Delete bsp_smp_cpu_state and replace it with Per_CPU_State. The
Per_CPU_State follows the Score naming conventions. Add
_Per_CPU_Change_state() and _Per_CPU_Wait_for_state() functions to
change and observe states.
Use Per_CPU_State in Per_CPU_Control instead of the anonymous integer.
Add _CPU_Processor_event_broadcast() and _CPU_Processor_event_receive()
functions provided by the CPU port. Use these functions in
_Per_CPU_Change_state() and _Per_CPU_Wait_for_state().
Add prototype for _SMP_Send_message().
Delete RTEMS_BSP_SMP_FIRST_TASK message. The first context switch is
now performed in rtems_smp_secondary_cpu_initialize(). Issuing the
first context switch in the context of the inter-processor interrupt is
not possible on systems with a modern interrupt controller. Such an
interrupt controler usually requires a handshake protocol with interrupt
acknowledge and end of interrupt signals. A direct context switch in an
interrupt handler circumvents the interrupt processing epilogue and may
leave the system in an inconsistent state.
Release lock in rtems_smp_process_interrupt() even if no message was
delivered. This prevents deadlock of the system.
Simplify and format _SMP_Send_message(),
_SMP_Request_other_cores_to_perform_first_context_switch(),
_SMP_Request_other_cores_to_dispatch() and
_SMP_Request_other_cores_to_shutdown().
Do not call bsp_smp_secondary_cpu_initialize() in
rtems_smp_secondary_cpu_initialize(). This allows more flexibilty in
the BSP low-level code. Specify context requirements for a call to
Call _SMP_Handler_initialize() later and move bsp_smp_initialize() into
_SMP_Handler_initialize(). Change bsp_smp_initialize() prototype to
match integer types of calling context.
Delete rtems_configuration_get_smp_maximum_processors(). Delete
rtems_configuration_smp_maximum_processors variable. Add
maximum_processors field to rtems_configuration_table if RTEMS_SMP is
defined. Add rtems_configuration_get_maximum_processors().
+ libbsp/sparc/shared/include/pci.h was largely a copy of
an older version of the cpukit pci.h. Removed much of the
contents and included <rtems/pci.h>.
+ sparc/*/pci*.c - Move to <rtems/pci.h> required updating
to use uint32_t for dword accesses.
+ Rename PCI_MULTI_FUNCTION to PCI_HEADER_TYPE_MULTI_FUNCTION
+ Define PCI_HEADER_TYPE_MULTI_FUNCTION in cpukit pci.h and remove
PCI_MULTI_FUNCTION definitions in C files.
+ Move PCI_INVALID_VENDORDEVICEID definitions from various C files
to cpukit pci.h
* shared/pci/pcibios.c: Make pcib_find_by_devid static.
PR 1925
* shared/irq/irq.h: Changed i386 console to libchip style console and
added support for com3 and com4.
* shared/comm/uart.c (uartError): Remove unused var "uartStatus".
* shared/comm/uart.c: Remove unused var "tmp".
PR 1802
* shared/irq/apic.h, shared/smp/smp-imps.c, shared/smp/smp-imps.h:
Reformat to be more compliant with RTEMS style.
* shared/irq/apic.h, shared/smp/smp-imps.c, shared/smp/smp-imps.h: Per
email with Erich Boleyn, change license to BSD style.
* shared/irq/irq.c, shared/irq/irq.h, shared/irq/irq_init.c: Add
initial support for APIC.
* shared/irq/apic.h, shared/smp/README, shared/smp/smp-imps.c,
shared/smp/smp-imps.h: New files.
* shared/comm/tty_drv.c, shared/comm/tty_drv.h:
Remove CVS-Headers. Add CVS-Ids.
* shared/irq/irq_asm.S: Rename rtems_smp_maximum_processors to
rtems_configuration_smp_maximum_processors since it is defined in
confdefs.h.
PR 1768/bsps
* shared/irq/irq_asm.S: The nbench benchmark highlighted the fact that
we do not perform a cld before calling C code in the ISR. This was
historically not a problem but gcc 4.3 changed the behavior. From
http://gcc.gnu.org/gcc-4.3/changes.html
PR 1729/cpukit
* shared/irq/irq_asm.S: Fix typo.
* shared/comm/gdb_glue.c, shared/comm/i386-stub.c,
shared/comm/i386_io.h, shared/comm/uart.c, shared/irq/idt.c,
* shared/irq/idt.c, shared/irq/irq.c, shared/irq/irq.h,
shared/irq/irq_asm.h: Fix typo where license said found in found in.
* shared/irq/irq_asm.S: Fix typo where license said found in found in.
* shared/irq/irq_asm.S: Fix spelling.
* shared/irq/irq_asm.S: Rename rtems_per_cpu_info.
PR 1573/cpukit
* shared/irq/irq.c, shared/irq/irq_asm.S: Add a per cpu data structure
which contains the information required by RTEMS for each CPU core.
This encapsulates information such as thread executing, heir, idle
and dispatch needed.
* shared/comm/GDB.HOWTO: Remove more ITRON references.
* shared/irq/irq_asm.S: Fix capitalization.
* shared/irq/irq-config.h: Removed file.
* shared/irq/irq.h: Moved defines from 'shared/irq/irq-config.h'.
PR 1483/cpukit
* shared/pci/pcibios.c: Rename pci_config into rtems_pci_config_t.
* shared/comm/uart.c, shared/comm/uart.h: Adjust prototypes.
* pc386/make/custom/pc586-sse.cfg, pc386/start/start.S,
shared/irq/irq_asm.S: Added experimental SSE support.
