* configure.ac, console/console.c: Add USE_COM1_AS_CONSOLE BSP option.
This makes it easy to build the pc386 BSP in a configuration that
corresponds to qemu with COM1 redirected to stdio.
* configure.ac: Remove explicit ampolish3 support (now in
RTEMS_BSP_CONFIGURE).
* configure.ac: Add ampolish3 support.
* Makefile.am: Add preinstall.am.
PR 649/bsps
* ide/idecfg.c, configure.ac:
added configuration items for primary/secondary IDE interface
* configure.ac: Add RTEMS_ROOT (HACK: This is the last file c/src
which still uses RTEMS_ROOT).
* configure.ac: Explicitly check for OBJCOPY.
* Makefile.am: Merge-in 3c509/Makefile.am, clock/Makefile.am,
console/Makefile.am, ide/Makefile.am, ne2000/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wd8003/Makefile.am,
wrapup/Makefile.am. Use automake compilation rules.
* 3c509/Makefile.am, clock/Makefile.am, console/Makefile.am,
ide/Makefile.am, ne2000/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wd8003/Makefile.am, wrapup/Makefile.am: Remove.
* start/start.S: Change comment to make it gcc -ansi compliant.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
Reflect changes to bsp.am.
PR 368/filesystems
* startup/ldsegs.S: Increase alignment.
* Makefile.am, configure.ac, include/bsp.h, wrapup/Makefile.am:
Added IDE supporting infrastructure.
* ide/Makefile.am, ide/ide.c, ide/idecfg.c: New files. Added
BSP support for libchip standard ide driver.
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* configure.ac: Remove duplicate timer/Makefile in AC_CONFIG_FILES.
* 3c509/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ne2000/Makefile.am: Remove AUTOMAKE_OPTIONS.
* wd8003/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR139
* configure.ac: Remove stray ';', breaks building with automake-1.6.
* configure.in: Remove.
