path: root/c/src/lib/libbsp/i386/pc386/Makefile.in (follow)
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-201-1/+1
* Inclusion of PC386 BSP submitted by Pedro Miguel Da Cruz Neto RomanoJoel Sherrill1997-12-011-0/+15
<pmcnr@camoes.rnl.ist.utl.pt> and Jose Rufino <ruf@asterix.ist.utl.pt> of NavIST (http://pandora.ist.utl.pt/).
