that converts the i386 directory to automake.
NOTE: Ralf is unable to build any i386 BSPs. This was true before and
after this patch and appears (to Joel) to be a tool issue unrelated since
others can build i386 BSPs.
dec21140 drivers from the i386/pc386 and powerpc/mcp750 (all Motorola
PowerPC boards) and move the network driver to libchip. This driver
should work on all PCI based uses of this chip.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
Both the ne2000 and the wd80x3 are based on the National Semiconductor
8390 chip, so there is a fair amount of overlap between the two
drivers. It would be possible in principle to combine some code into
a separate set of subroutines called by both. In fact, the drivers in
both OpenBSD and Linux work this way. I didn't bother, because for
the relatively simple drivers used by RTEMS, the overlap is not
especially large, and any reasonable use of subroutines would lead to
slightly less efficient code.
This ne2000 driver uses two transmit buffers. While one packet is
being transmitted over the Ethernet, RTEMS will upload another. Since
uploading a packet to the ne2000 is rather slow, I don't think there
is any point to having more than two transmit buffers. However, the
code does make it possible, by changing NE_TX_BUFS, although that
would of course reduce the number of receive buffers.
I suspect that the wd80x3 driver would benefit slightly from copying
the multiple transmit buffer code. However, I have no way to test
that.
moves pieces of the pc386 bsp up to a shared level for all i386 BSPs
and modifies the i386ex BSP to use those shared pieces. Serial remote
debugging is included for both targets. Erik's notes:
There are several workarounds in it:
1) #define NEXT_GAS is hardcoded in pc386/start/start.s
2) #define NEXT_GAS is hardcoded in i386ex/start/start.s
3) #define NEW_GAS is hardcoded in pc386/start16.s
4) #undef __assert and redeclare _assert hardcoded in console.c for
both pc386 and i386ex due to my egcs1.1b ~ newlib problem. Should have
modified t-rtems.cfg ( no time )
I've tested pc386 with both video and serial consoles and GDB remote.
All work fine, except that GDB acts weird. ( re: other posting)
I hope this will work for you. It took quite some time to locate the
autoconf error. The remainder was just grunt work.
Unfortunately, I think I've unwound the removal of the IBMPCInitVideo
stuff. Sorry. I REALLY can't spend more time... I've been at this
conversion to 4.0 locally and updating the release since Sept. 8th, and
have yet to compile my network driver.... This is as much as I can do
right now.
I look forward to the next patch to really test i368ex. I did make sure
that the sample tests worked for pc386.
I have reworked the ethernet driver for the BSP pc386 and
here is the patch to apply.
Here is a patch that enables to catch exception
and get message before crashing RTEMS :)
It should be generic to any Intel port although enabled
only for pc386 BSP...
[Joel] I fixed the bug I introduced in irq_asm.s...
<raguet@crf.canon.fr> to make their patches work together.
Here is a patch for KA9Q stack.
This patch contains an Ethernet Driver for Western Digital,
some fixes for the UDP and TCP protocols (for endian conversion)
and some little programs which allow the test of UDP and TCP
sockets via Ethernet.
I have tested that on an Intel machine. If someone can test it
on a big-endian machine, ...
<qqi@world.std.com>). Unfortunately after merging these,
the pc386 will not boot using grub for for. It still does not
work using netboot for me. Here is his summary of changes:
rtems/c/src/lib/libbsp/i386/pc386/Makefile.in
Added support for new sub-directory
rtems/c/src/lib/libbsp/i386/pc386/bsp_specs
Made possible to build COFF image
rtems/c/src/lib/libbsp/i386/pc386/console/console.c
Added support for serial consoles, selectable by patching
binary image, added __assert(), use _IBMPC_inch_sleep()
instaed of _IMBPC_inch()
rtems/c/src/lib/libbsp/i386/pc386/console/inch.c
Added _IMBPC_inch_sleep()
rtems/c/src/lib/libbsp/i386/pc386/console/outch.c
Oops - just formatting
rtems/c/src/lib/libbsp/i386/pc386/include/Makefile.in
Added support for new files
rtems/c/src/lib/libbsp/i386/pc386/include/bsp.h
Added support for new features
rtems/c/src/lib/libbsp/i386/pc386/include/pc386uart.h
New file: definitions for serial ports
rtems/c/src/lib/libbsp/i386/pc386/include/pcibios.h
New file: definitions for PCI BIOS
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/Makefile.in
New file: makefile in new directory
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub-glue.c
New file: i386-stub interface
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub.c
New file: i386-stub itself
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pc386uart.c
New file: serial ports
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pcibios.c
New file: PCI BIOS support
rtems/c/src/lib/libbsp/i386/pc386/start/start.s
Commented out DEBUG_EARLY stuff, everything is working fine
rtems/c/src/lib/libbsp/i386/pc386/start/start16.s
Cleaned up
rtems/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
Added call to console_resereve_resources
rtems/c/src/lib/libbsp/i386/pc386/startup/exit.c
rtems/c/src/lib/libbsp/i386/pc386/startup/ldsegs.s
Fixed typo in comments
rtems/c/src/lib/libbsp/i386/pc386/tools/Makefile.in
Changed to reflect cnages in code
rtems/c/src/lib/libbsp/i386/pc386/tools/bin2boot.c
Trivialized, problem - I do not know how to make patch
remove obsolete files - there are a lot of them there
rtems/c/src/lib/libbsp/i386/pc386/tools/binpatch.c
New file: utility to do binary patches
rtems/c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in
Added support for new directory
rtems/make/custom/pc386.cfg
Add COFF image building
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
<pmcnr@camoes.rnl.ist.utl.pt> and Jose Rufino <ruf@asterix.ist.utl.pt>
of NavIST (http://pandora.ist.utl.pt/).
