* clock/Makefile.am: Misc cleanups and fixes.
* Makefile.am: Add dirstamps to preinstallation.
* acinclude.m4: Reflect changes to bootstrap.
* configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
Reflect changes to bsp.am.
* bsp_specs: Remove *lib:.
* console/console-io.c, include/bsp.h, startup/bspstart.c: URL for
license changed.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* startup/bspstart.c: Add empty H8BD_Install_IRQ so the port will have
a routine to call.
* startup/bspstart.c: Remove ramStart to eliminate warning.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* startup/bspstart.c, startup/linkcmds: Per PR247 , fix the linkcmds
to avoid overlapping sections and reworked the way the heap and
workspace are calculated.
* wrapup/Makefile.am: Add $(LIB) to all-local.
* console/console-io.c: Include rtems/bspIo.h instead of bspIo.h.
* console/console-io.c: Fixed typo.
* configure.in: Remove.
* acinclude.m4: New file.
