path: root/c/src/lib/libbsp/h8300 (follow)
* Remove H8300 portJoel Sherrill2016-01-043-34/+0
| | | | updates #2452.
* h8300: Regenerate h8300 architectureAun-Ali Zaidi2015-12-142-3/+1
| | | | closes #2453.
* h8300/h8sim: RemoveAun-Ali Zaidi2015-12-1315-584/+0
| | | | updates #2453.
* bsps: Delete superfluous bsp_pretasking_hook()Sebastian Huber2015-12-101-1/+0
| | | | | | Use the bsp_predriver_hook() instead. Update #2408.
* Add RTEMS linker setsSebastian Huber2015-12-081-0/+2
| | | | Update #2408.
* h8sim-testsuite.tcfg: Add fsdosfsname01Joel Sherrill2015-10-201-0/+1
| | | | closes #2432.
* Most bsp.h: Switch to LIBBSP_@CPU@_@BSP_FAMILY@_H for guardJoel Sherrill2015-07-161-2/+2
| | | | | | | | | | | | | | | | | This was done by the following script run from libbsp: find * -name bsp.h | xargs -e grep -l "#ifndef.*_BSP_H" | while read b do echo $b cpu=`echo $b | cut -d'/' -f1 | tr '[:lower:]' '[:upper:]' ` bsp=`echo $b | cut -d'/' -f2 | tr '[:lower:]' '[:upper:]' ` g="LIBBSP_${cpu}_${bsp}_BSP_H" # echo $g sed -e "s/ifndef _BSP_H/ifndef ${g}/" \ -e "s/define _BSP_H/define ${g}/" \ -i $b done
* h8sim*-testsuite.tcfg: Add tests with data size issuesJoel Sherrill2015-03-222-1/+9
* h8sim: Disable jffs2 and mrfs testsJoel Sherrill2015-03-222-0/+4
* Update bug report URLSebastian Huber2014-12-052-2/+2
* bsps: Move extern "C" to not cover includesSebastian Huber2014-10-231-4/+4
| | | | Some includes may use C++ and this conflicts if surrounded extern "C".
* h8300/h8sim: Exit simulator cleanlyJoel Sherrill2014-10-153-11/+20
* h8300/h8sim/startup/__main.c: Removed. Obsolete remnant of COFF.Joel Sherrill2014-10-151-21/+0
* h8sxsim-testsuite.tcfg: Disable capture test - uses too many task tasks for BSPJoel Sherrill2014-10-131-0/+1
* Add console-polled.h and update all BSPs that should use it.Joel Sherrill2014-10-103-2/+8
| | | | | | | | | | | The file console-polled.h provides the prototypes for the three required methods when implementing a single port polled console driver. This paradigm is common on simulators and simple hardware. + Updated the BSPs Makefile.am to make console-polled.h available. + Regenerated the BSPs preinstall.sm. + Updated console support files to include <bsp/console-polled.h>. + Updated console support files to make printk() support method static.
* Regenerate all preinstall.am files.Chris Johns2014-08-291-6/+6
| | | | | With this patch the preinstall.am files are in a set order and not dependent on now perl implements a hash.
* Add More Testsuite Configuration Files and Update Existing OnesJoel Sherrill2014-07-162-0/+4
| | | | | | | The first pass at building these was without networking enabled. This pass addresses that plus accounts for some new BSPs which needed testsuite.tcfg files and BSPs which could not link tests which had been added since the first pass.
* bsps: Do not build tests that require a tick interrupt.Chris Johns2014-05-282-0/+10
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | The following BSPs do not have tick support so the tests fail: arm1136jfs arm1136js arm7tdmi arm920 armcortexa9 (does not run any more) avrtest h8sim h8sxsim m32csim m32rsim moxiesim simsh1 simsh2 simsh4 v850e1sim v850e2sim v850e2v3sim v850esim v850essim v850sim This list was provided by Joel in the following post: http://www.rtems.org/pipermail/rtems-devel/2014-April/006526.html
* bsp/h8sim: Fix linker command fileSebastian Huber2014-04-291-0/+2
* h8sim/bsp_specs: Add crtbegin/end, crt[in]Joel Sherrill2014-04-221-1/+4
* bsps: Fix TLS support in linker command filesSebastian Huber2014-04-221-1/+3
| | | | | The TLS section symbols had wrong values in case of an empty TLS data section and a nonempty TLS BSS section.
* h8sim/console/console-io.c: Comment clean upJoel Sherrill2014-04-031-1/+3
* h8sim/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-16/+0
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-213-3/+3
* bsps: Add empty cache managerSebastian Huber2014-02-241-0/+5
| | | | | This is necessary to add tests that use the cache manager. For example to get better estimates of worst-case timings.
* bsps: Thread-local storage (TLS) for linkcmdsSebastian Huber2014-02-041-1/+15
* libbsp misc: Fix comment formattingJoel Sherrill2013-12-301-18/+15
* h8sim: Add Doxygen directivesSzkocsovszki Zsolt2013-12-282-1/+31
* RTEMS: Delete ChangeLog files.Gedare Bloom2013-03-082-705/+0
| | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain.
* score: Add RTEMS_FATAL_SOURCE_EXITSebastian Huber2012-11-151-0/+1
| | | | | | | Include <bsp/default-initial-extension.h> in all BSPs. Call rtems_fatal() with RTEMS_FATAL_SOURCE_EXIT as source and the exit() status code as fatal code in every bsp_cleanup(). Move previous bsp_cleanup() code into bsp_fatal_extension().
* Revert "Add bspopts.h.in."Gedare Bloom2012-08-061-31/+0
| | | | | | | | | | | | This reverts commit daffa606cc4a45d93c1f0f4fe365fde0fda6acbb. Conflicts: c/src/lib/libbsp/arm/lpc24xx/include/bspopts.h.in c/src/lib/libbsp/powerpc/mpc55xxevb/include/bspopts.h.in c/src/lib/libbsp/powerpc/qoriq/include/bspopts.h.in Manually deleted conflicting files.
* Require automake-1.12.2.Ralf Corsépius2012-07-192-2/+2
* Require autoconf-2.69.Ralf Corsépius2012-07-192-2/+2
* Add bspopts.h.in.Ralf Corsépius2012-05-241-0/+31
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-118-18/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-044-12/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-013-21/+0
* 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-06-202-2/+4
| | | | * Makefile.am: Don't reference non-existing files.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-112-1/+6
| | | | | * include/bsp.h: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-024-4/+12
| | | | * configure.ac: Require autoconf-2.68, automake-1.11.1.
* Whitespace removal.Ralf Corsepius2009-11-282-2/+2
* 2009-11-09 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-11-092-5/+5
| | | | * start/start.S: Remove warning.
* 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-213-6/+5
| | | | | * make/custom/h8sim.cfg: Remove RTEMS_BSP_FAMILY. * make/custom/h8sxsim.cfg: Remove RTEMS_BSP_FAMILY.
* 2009-10-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-202-1/+5
| | | | * configure.ac: Don't add -ansi -fasm to CFLAGS.
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-153-0/+47
| | | | | * make/custom/h8sim.cfg: New (relocated from /make/custom). * make/custom/h8sxsim.cfg: New (relocated from /make/custom).
* 2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-09-152-2/+5
| | | | * configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* 2009-07-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-162-1/+8
| | | | | | * configure.ac: Rename BSP_BOOTCARD_OPTIONS to RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs have the same options.
* 2009-04-28 Chris Johns <chrisj@rtems.org>Chris Johns2009-04-282-0/+9
| | | | * start/start.S: Update for boot_card command line change.
* 2008-12-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-042-2/+8
| | | | | | * bsp_specs: Move -e start from *link to *startfile to avoid warning for undefined entry symbol when linking relocatables with binutils 2.19.
* 2008-10-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-10-142-1/+5
| | | | | * startup/linkcmds: Do not specify architecture since the linker gets it right even with multiple variants.
