start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am.
startup/Makefile.am, wrapup/Makefile.am: Remove.
Use automake compilation rules.
* start/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* startup/Makefile.am: Ditto.
* Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of
$(RTEMS_BSP_FAMILY).
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* clock/Makefile.am: Misc cleanups and fixes.
* Makefile.am: Add dirstamps to preinstallation.
* acinclude.m4: Reflect changes to bootstrap.
* configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
Reflect changes to bsp.am.
* bsp_specs: Remove *lib:.
* console/console-io.c, include/bsp.h, startup/bspstart.c: URL for
license changed.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* startup/bspstart.c: Add empty H8BD_Install_IRQ so the port will have
a routine to call.
* startup/bspstart.c: Remove ramStart to eliminate warning.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* startup/bspstart.c, startup/linkcmds: Per PR247 , fix the linkcmds
to avoid overlapping sections and reworked the way the heap and
workspace are calculated.
* wrapup/Makefile.am: Add $(LIB) to all-local.
* console/console-io.c: Include rtems/bspIo.h instead of bspIo.h.
* console/console-io.c: Fixed typo.
