path: root/c/src/lib/libbsp/h8300 (follow)
* Remove eof include fileRalf Corsepius2006-03-171-1/+0
* 2006-02-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-02-082-11/+16
| | | | * startup/linkcmds: Add sections required by newer gcc versions.
* Regenerate.Ralf Corsepius2006-01-141-1/+1
* Regenerate.Ralf Corsepius2006-01-121-0/+4
* Remove all-local:.Ralf Corsepius2006-01-121-2/+0
* Regenerate.Ralf Corsepius2006-01-121-1/+1
* Cleanup.Ralf Corsepius2006-01-121-3/+0
* New.Ralf Corsepius2006-01-111-0/+54
* 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-01-112-45/+6
| | | | * Makefile.am: Add preinstall.am.
* 2005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-05-262-2/+6
| | | | * include/bsp.h: New header guard.
* 2005-05-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-05-112-1/+5
| | | | * startup/linkcmds: Add .rodata.* sections.
* 2005-03-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-03-072-1/+10
| | | | * Makefile.am: Add timerstub so more tests link.
* 2005-03-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-03-072-7/+11
| | | | * startup/linkcmds: Hacked so there is enough memory to link pppd.exe.
* 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-072-3/+7
| | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-032-51/+19
| | | | * Makefile.am: Remove build-variant support.
* 2004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-09-293-9/+10
| | | | | * include/bsp.h, include/tm27.h: i960 obsoleted and all references removed.
* Fix typo in previous change.Ralf Corsepius2004-09-242-2/+2
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-244-2/+10
| | | | * configure.ac: Require automake > 1.9.
* 2004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-233-2/+13
| | | | | | PR 610/bsps * Makefile.am: Add include/tm27.h, Cosmetics. * include/tm27.h: Final cosmetics.
* 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-223-17/+37
| | | | | * include/bsp.h: Split out tmtest27 support. * include/tm27.h: New.
* 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-212-10/+5
| | | | | PR 613/bsps * include/bsp.h: Remove MAX_LONG_TEST_DURATION.
* 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-212-1/+5
| | | | | PR 614/bsps * include/bsp.h: Remove MAX_SHORT_TEST_DURATION (Unused).
* Remove stray white spaces.Ralf Corsepius2004-04-214-9/+9
* Remove stray white spaces.Ralf Corsepius2004-04-151-2/+0
* 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-012-3/+9
| | | | | | * include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. * include/bsp.h: Include <rtems/iosupp.h> instead of <iosupp.h>.
* 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-313-4/+9
| | | | | * include/bsp.h, startup/bspstart.c: Convert to using c99 fixed size types.
* Remove refs to Makefile*.Ralf Corsepius2004-03-091-2/+0
* 2004-02-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-192-2/+35
| | | | | * Makefile.am: Reflect changes to bsp.am. Preinstall dist_project_lib*.
* 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-142-1/+5
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-122-2/+6
| | | | * acinclude.m4: Regenerate.
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-122-1/+5
| | | | * configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]).
| | | | * Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Remove uncessary .cvsignoreRalf Corsepius2004-01-295-10/+0
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-298-178/+97
| | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am. * clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am: Remove. Use automake compilation rules. * configure.ac: Reflect changes above.
* 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-212-0/+9
| | | | * Makefile.am: Add PREINSTALL_DIRS.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-143-0/+16
| | | | | | * start/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * startup/Makefile.am: Ditto.
* 2004-01-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-132-2/+7
| | | | | * Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of $(RTEMS_BSP_FAMILY).
* 2004-01-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-052-8/+7
| | | | | * wrapup/Makefile.am: Eliminate $(LIB). Use noinst_DATA to trigger building libbsp.a.
* 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-133-12/+17
| | | | | * start/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. * startup/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-123-0/+13
| | | | | * start/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * startup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-124-4/+12
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-105-22/+23
| | | | | | | * clock/Makefile.am: Misc cleanups and fixes. * start/Makefile.am: Misc cleanups and fixes. * startup/Makefile.am: Misc cleanups and fixes. * wrapup/Makefile.am: Misc cleanups and fixes.
* 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-026-7/+13
| | | | | | | | * Makefile.am: Add dirstamps to preinstallation. * clock/Makefile.am: Cosmetics. * console/Makefile.am: Cosmetics. * startup/Makefile.am: Cosmetics. * wrapup/Makefile.am: Cosmetics.
* 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-026-5/+13
| | | | | | | | * clock/Makefile.am: Remove all-local: $(ARCH). * console/Makefile.am: Remove all-local: $(ARCH). * start/Makefile.am: Remove all-local: $(ARCH). * startup/Makefile.am: Remove all-local: $(ARCH). * wrapup/Makefile.am: Remove all-local: $(ARCH).
* 2003-10-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-203-3/+6
| | | | | * acinclude.m4: Reflect changes to bootstrap. * configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
* 2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-294-30/+19
| | | | | | | * Makefile.am: Merge-in include/Makefile.am. Reflect changes to bsp.am. * include/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2003-09-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-082-8/+4
| | | | * bsp_specs: Remove *lib:.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-044-3/+8
| | | | | * console/console-io.c, include/bsp.h, startup/bspstart.c: URL for license changed.
* 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-184-2/+10
| | | | * Makefile.am: Reflect having moved aclocal/.
* Fix broken ChangeLog entries.Ralf Corsepius2003-08-182-8/+8
