The file console-polled.h provides the prototypes for the three
required methods when implementing a single port polled console
driver. This paradigm is common on simulators and simple hardware.
+ Updated the BSPs Makefile.am to make console-polled.h available.
+ Regenerated the BSPs preinstall.sm.
+ Updated console support files to include <bsp/console-polled.h>.
+ Updated console support files to make printk() support method static.
The first pass at building these was without networking enabled.
This pass addresses that plus accounts for some new BSPs which
needed testsuite.tcfg files and BSPs which could not link tests
which had been added since the first pass.
The following BSPs do not have tick support so the tests fail:
arm1136jfs
arm1136js
arm7tdmi
arm920
armcortexa9 (does not run any more)
avrtest
h8sim
h8sxsim
m32csim
m32rsim
moxiesim
simsh1
simsh2
simsh4
v850e1sim
v850e2sim
v850e2v3sim
v850esim
v850essim
v850sim
This list was provided by Joel in the following post:
http://www.rtems.org/pipermail/rtems-devel/2014-April/006526.html
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Conflicts:
* Makefile.am: Don't reference non-existing files.
* include/bsp.h:
* start/start.S: Remove warning.
* make/custom/h8sim.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/h8sxsim.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/h8sim.cfg: New (relocated from /make/custom).
* make/custom/h8sxsim.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* startup/linkcmds: Do not specify architecture since the linker gets
it right even with multiple variants.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* console/console-io.c: Add missing file and remove junk code.
* console/syscalls.S: New file.
* startup/linkcmds: Simulator now appears to have 16M RAM support by
default in gdb 6.8.
* Makefile.am, console/console-io.c, include/bsp.h:
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am: Split out bspstart contents. Use shared stub for
bsp_start.
* startup/h8bdinstallirq.c: New file.
* startup/bspstart.c: Removed.
