* ChangeLog: Removed bad entry.
* console/console-io.c: Added console_initialize_hardware().
* Makefile.am, clock/Makefile.am, clock/.cvsignore, wrapup/Makefile.am:
Added include of stub clock driver so ticker would link.
* configure.in, Makefile.am, clock/Makefile.am, clock/.cvsignore,
wrapup/Makefile.am: Added include of stub clock driver so ticker
would link.
* startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and
* console/Makefile.am, start/Makefile.am, startup/Makefile.am,
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
