* startup/umonsupp.c: Include <rtems/umon.h> (Missing prototype).
* misc/system-clocks.c: New file.
* Makefile.am: Reflect change from above.
* include/nand-mlc.h: Fixed lpc32xx_mlc_is_bad_page().
* make/custom/lpc32xx.inc, make/custom/lpc32xx_mzx_stage_1.cfg: Flags
for EABI tool chain.
* configure.ac, include/bsp.h, include/lpc32xx.h, misc/emc.c,
misc/i2c.c, rtc/rtc-config.c, startup/bspstarthooks.c: Avoid compile
time ARM_CLK and HCLK.
* make/custom/lpc24xx.inc: Flags for EABI tool chain.
* Makefile.am: Add shared/startup/bsp-start-memcpy.S
* include/lpc17xx.h: New file.
* Makefile.am, preinstall.am: Reflect change above. Update due to API
changes.
* configure.ac, console/console-config.c, include/bsp.h, include/io.h,
include/irq.h, include/lcd.h, include/lpc-clock-config.h,
include/lpc24xx.h, include/start-config.h, irq/irq-dispatch.c,
irq/irq.c, misc/bspidle.c, misc/io.c, misc/lcd.c, misc/restart.c,
misc/system-clocks.c, ssp/ssp.c, startup/bspreset.c,
startup/bspstart.c, startup/bspstarthooks.c,
startup/start-config-emc-dynamic.c, startup/start-config-emc-static.c,
startup/start-config-pinsel.c: Basic support for LPC17XX. New memory
configurations for W9825G2JB75I, IS42S32800B, and SST39VF3201.
* shared/startup/bsp-start-copy-sections.c,
shared/startup/bsp-start-memcpy.S: New files.
* shared/include/start.h: Declare bsp_start_copy_sections().
* shared/start/start.S, shared/include/linker-symbols.h: Moved
content. Support for ARMv7-M.
PR 1953/bsps
* console/uart.c: Do not use /dev/console in libchip configuration
table. Shared driver framework selects device to use as /dev/console.
PR 1953/bsps
* console/uarts.c: Do not use /dev/console in libchip configuration
* console/console-config.c: Avoid explicit type.
PR 1951/bsps
* Makefile.am, console/console-config.c: Update due to API changes.
PR 1917/bsps
* Makefile.am: Modifications to add dynamic tables for libchip serial
drivers.
PR 1917/bsps
* Makefile.am, console/uarts.c: Modifications to add dynamic tables for
libchip serial drivers.
PR 1917/bsps
* Makefile.am, console/uart.c: Modifications to add dynamic tables for
PR 1917/bsps
* Makefile.am, console/console-config.c: Modifications to add dynamic
tables for libchip serial drivers.
PR 1917/bsps
* Makefile.am, console/console-config.c, console/hsu.c: Modifications
to add dynamic tables for libchip serial drivers.
* include/start-config.h, make/custom/lpc24xx_plx800_rom_int.cfg,
startup/linkcmds.lpc24xx_plx800_rom_int,
startup/start-config-pinsel.c: New files.
* Makefile.am, configure.ac, preinstall.am: Reflect changes above.
* startup/bspstarthooks.c: Use configuration tables for EMC
initialization.
* make/custom/rtl22xx_t.cfg: Remove USE_THUMB (Violates *.cfg
conventions, unused).
* acinclude.m4: Added lm3s69xx BSP.
* 0001-Fixed-interrupt-handling-for-ARMv7M.patch,
0002-Fixed-system-handler-priority-register-access.patch,
0003-Disable-priority_mask-unused-for-NVIC.patch, 0004-Typo.patch,
0005-Evil-hack-for-BASEPRI-BASEPRI_MAX.patch,
0006-Evil-hack-to-increase-the-RAM-size.patch, bsp_specs, ChangeLog,
clock/clock-config.c, configure.ac, console/console-config.c,
console/uart.c, .cvsignore, include/bsp.h, include/.cvsignore,
include/irq.h, include/lm3s69xx.h, include/uart.h, irq/irq.c,
make/custom/lm3s6965.cfg, make/custom/lm3s69xx.inc, Makefile.am,
README, start/start.S, startup/bspreset.c, startup/bspstart.c,
startup/bspstarthook.c, startup/linkcmds.lm3s6965, timer/timer.c: New
files.
* make/custom/lpc32xx.inc: Workaround for GCC bug 50106.
* include/lpc32xx.h: Fixed register map for NAND MLC.
* include/boot.h: Declare lpc32xx_set_boot_block_bad().
* misc/boot.c: Define lpc32xx_set_boot_block_bad().
* include/nand-mlc.h, misc/nand-mlc-erase-block-safe.c,
misc/nand-mlc-read-blocks.c, misc/nand-mlc-write-blocks.c,
misc/nand-mlc.c: Changed bad block handling. Support for non-aligned
data. Documentation.
* startup/linkcmds: Fixed instruction cache size.
* start/start.S: Fixed code section.
* irq/irq.c: Removed printk() before the interrupt initialization
because it somehow destroys the interrupt context.
* make/custom/nds.cfg: Enable Thumb interwork.
* startup/bspstart.c: Set default exception handler.
* irq/irq-dispatch.c: New file.
* irq/irq.c: Moved bsp_interrupt_dispatch() to new file.
* misc/i2c.c: Bugfix.
* include/.cvsignore: New file.
* include/bspopts.h.in: Removed file.
* include/lpc24xx.h: Added ADC defines.
* make/custom/lpc24xx.inc: Workaround for GCC bug 49641.
* misc/nand-mlc-erase-block-safe.c, misc/nand-mlc-write-blocks.c,
include/nand-mlc.h: Fixed write blocks.
Sebastian Huber <sebastian.huber@embedded-brains.de>
* misc/nand-mlc-erase-block-safe.c: New file
* misc/nand-mlc-write-blocks.c: Use lpc32xx_mlc_erase_block_safe_3().
* include/nand-mlc.h: Bad block handling.
* Makefile.am: Fix broken path to cache_.h.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* Makefile.am, preinstall.am: Cache manager changes.
* i2c/i2c-config.c: New file.
* include/lcd.h: Removed EMC definitions.
* misc/dma.c: Fixed initialization.
* include/i2c.h, include/io.h, include/lpc-ethernet-config.h,
include/lpc24xx.h, console/console-config.c, i2c/i2c.c, misc/io.c,
misc/lcd.c, startup/bspstart.c, startup/bspstarthooks.c: New pin
configuration API.
* Makefile.am, preinstall.am: Update.
* Makefile.am, preinstall.am: Install new header files.
* include/bsp.h, include/emc.h, include/lpc32xx.h, misc/emc.c: Update
for API changes.
* shared/lpc/include/lpc-emc.h, shared/lpc/include/lpc-lcd.h: New
files.
* shared/lpc/include/lpc-dma.h: API changes.
* shared/lpc/clock/lpc-clock-config.c: Fixed nano seconds extension.
* shared/lpc/network/lpc-ethernet.c: Format. Multicast hash filter
support.
* shared/lpc/network/lpc-ethernet.c: Support multicast.
* configure.ac, include/bspopts.h.in: New BSP option
LPC32XX_SCRATCH_AREA_SIZE. Disable BSP option
LPC32XX_DISABLE_READ_ONLY_PROTECTION for all BSPs.
* include/boot.h: Removed application specific defines.
* include/nand-mlc.h, misc/nand-mlc.c: Changed configuration layout.
* include/mmu.h, misc/mmu.c: Documentation. Bugfix.
* include/bsp.h, startup/bspstarthooks.c, misc/restart.c,
startup/linkcmds.lpc32xx_mzx, startup/linkcmds.lpc32xx_mzx_stage_1,
startup/linkcmds.lpc32xx_mzx_stage_2,
startup/linkcmds.lpc32xx_phycore: Support for scratch area. Moved
code into macros for reusability.
* shared/start/start.S: Default exception handler will result in
bsp_reset().
* shared/startup/linkcmds.base: Move unsupported sections into
read-only section. Changed barrier sections.
* README: Add example mkimage command.
