* network/network.c: Changes to network driver to get it to compile
again.
* startup/linkcmds: Add gnu.linkonce.r sections.
* .cvsignore: New file.
* acinclude.m4: Added csb336 and csb337 BSPs
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
times, console/uarts.c, include/.cvsignore, include/bsp.h,
include/tm27.h, network/.cvsignore, network/network.c,
start/.cvsignore, start/start.S, startup/.cvsignore,
startup/bspstart.c, startup/exit.c, startup/linkcmds,
startup/memmap.c: New files.
* console/.cvsignore, include/.cvsignore, network/.cvsignore,
start/.cvsignore, startup/.cvsignore: New files.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, times,
console/uart.c, include/bsp.h, include/tm27.h, network/lan91c11x.c,
network/lan91c11x.h, network/network.c, start/start.S,
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* startup/bspstart.c: Convert to using c99 fixed size types.
* console/uart.c, include/ep7312.h, startup/bspstart.c,
timer/timer.c: Convert to using c99 fixed size types.
* startup/linkcmds: Add more memory and sections so tests can link.
This is a generic BSP for a CPU model so OK to do this.
* startup/linkcmds: Add more memory so tests can link. This is a
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* acinclude.m4: Regenerate.
* configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]).
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Pickup files from ../../arm/shared instead of
../shared. Reformat.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* include/bsp.h: Remove config.
* irq/irq.c: Remove stray blanks.
* start/start.S: Add missing */ in comments.
* start/start.S, startup/libcfunc.c, startup/syscalls.c:
Include bspopts.h for ARM_RDI_MONITOR.
network/Makefile.am, irq/Makefile.am, start/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake
compilation rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
irq/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am: Remove.
timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, irq/Makefile.am,
* irq/Makefile.am: Ditto.
* start/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* startup/Makefile.am: Ditto.
* start/Makefile.am: Ditto.
* Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of
$(RTEMS_BSP_FAMILY).
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* startup/linkcmds: Remove SEARCH_DIR.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
