path: root/c/src/lib/libbsp/arm/shared (follow)
* Remove unused .cvsignoreRalf Corsepius2004-01-282-4/+0
* 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-212-1/+7
| | | | * Makefile.am: Add PREINSTALL_DIRS.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-142-0/+8
| | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-2/+5
| | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-032-0/+15
| | | | * Makefile.am: Add preinstallation dirstamp support.
* 2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-034-37/+11
| | | | | | * Makefile.am: Merge-in comm/Makefile.am, irq/Makefile.am * comm/Makefile.am: Remove. * irq/Makefile.am: Remove.
* 2003-09-15 Jay Monkman <jtm@smoothsmoothie.com>Jennifer Averett2003-09-151-6/+0
| | | | | PR 480/bsps * shared/irq/irq_asm.S: Remove duplicate code.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-046-5/+10
| | | | | * comm/console.c, comm/uart.c, comm/uart.h, irq/irq_asm.S, irq/irq_init.c: URL for license changed.
* Fix broken ChangeLog entries.Ralf Corsepius2003-08-181-3/+3
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-164-4/+10
| | | | | | Makefile.am: Reflect having moved automake. comm/Makefile.am: Reflect having moved automake. irq/Makefile.am: Reflect having moved automake.
* 2002-11-13 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2002-11-133-1/+11
| | | | | * irq/irq_asm.S, irq/irq_init.c: Fixes a bug with handling the situation where we are processing an IRQ, and we receive an FIQ.
* 2002-10-04 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2002-10-042-0/+10
| | | | * irq/irq_asm.S: Add FIQ support.
* 2002-07-30 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2002-07-302-17/+20
| | | | | | | * irq/irq_asm.S: ARM port works well enough to run all sptests, tmtests, and ttcp. In addition to general cleanup, there has been considerable optimization to interrupt disable/enable, endian swapping, and context switching.
* 2002-07-17 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2002-07-172-89/+154
| | | | | * irq/irq_asm.S: Significant rework in attempt to make interrupts work. They appear to be very close to correct but not 100%.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-284-3/+6
| | | | | | * comm/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * irq/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-01-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-043-2/+7
| | | | | * comm/console.c: Include rtems/bspIo.h instead of bspIo.h. * irq/irq_init.c: Include rtems/bspIo.h instead of bspIo.h.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-1/+5
| | | | * comm/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-05-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-242-3/+8
| | | | * comm/Makefile.am: Use *_HEADERS instead of *H_FILES.
* 2000-12-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-063-12/+11
| | | | | * comm/console.c: Added casts to eliminate warnings. * comm/console.c (console_reserve_resources): Removed.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-053-7/+7
| | | | | * Makefile.am, shared/Makefile.am, shared/comm/Makefile.am, shared/irq/Makefile.am: Include compile.am
* Minor problems addressed with the merger and with the arm_bare_bsp.Joel Sherrill2000-07-277-178/+4
| | | | | | That BSP now has a stub clock driver so the tests can link even if they won't execute. A handful of Makefiles had to be updated and we had to account for printk.c being a shared file now.
* Port of RTEMS to the ARM processor family by Eric ValetteJoel Sherrill2000-07-2715-0/+1489
<valette@crf.canon.fr> and Emmanuel Raguet <raguet@crf.canon.fr> of Canon CRF - Communication Dept. This port includes a basic BSP that is sufficient to link hello world.
