* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Merge-in comm/Makefile.am, irq/Makefile.am
* comm/Makefile.am: Remove.
* irq/Makefile.am: Remove.
PR 480/bsps
* shared/irq/irq_asm.S: Remove duplicate code.
* comm/console.c, comm/uart.c, comm/uart.h, irq/irq_asm.S,
irq/irq_init.c: URL for license changed.
comm/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
* irq/irq_asm.S, irq/irq_init.c: Fixes a bug with handling the
situation where we are processing an IRQ, and we receive an FIQ.
* irq/irq_asm.S: Add FIQ support.
* irq/irq_asm.S: ARM port works well enough to run all sptests,
tmtests, and ttcp. In addition to general cleanup, there
has been considerable optimization to interrupt disable/enable,
endian swapping, and context switching.
* irq/irq_asm.S: Significant rework in attempt to make interrupts
work. They appear to be very close to correct but not 100%.
* comm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* comm/console.c: Include rtems/bspIo.h instead of bspIo.h.
* irq/irq_init.c: Include rtems/bspIo.h instead of bspIo.h.
* comm/Makefile.am: Use 'PREINSTALL_FILES ='.
* comm/Makefile.am: Use *_HEADERS instead of *H_FILES.
* comm/console.c: Added casts to eliminate warnings.
* comm/console.c (console_reserve_resources): Removed.
* Makefile.am, shared/Makefile.am, shared/comm/Makefile.am,
shared/irq/Makefile.am: Include compile.am
That BSP now has a stub clock driver so the tests can link even
if they won't execute. A handful of Makefiles had to be updated
and we had to account for printk.c being a shared file now.
