* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* Makefile.am, configure.ac, console/uart.c, startup/bspstart.c: Use
standardized bsp_cleanup() which can optionally print a message, poll
for user to press key, and call bsp_reset(). Using this eliminates
the various bsp_cleanup() implementations which had their own
implementation and variety of string constants.
* startup/bspclean.c: Removed.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* Makefile.am, configure.ac, startup/bspstart.c: Split out
bsp_get_work_area() into its own file and user BSP Framework to
perform more initialization. Use same shared implementation as
edb7312 and csb336.
* Makefile.am: Rework to avoid .rel files.
* Makefile.am, include/bsp.h, startup/bspstart.c: Moved most of the
remaining CPU Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* Makefile.am: Add abort.rel since it is now in the BSP shared source,
not in score/cpu.
* Makefile.am, console/lpc22xx_uart.h: Remove warnings, cleanup and do
not build SPARC code accidentally referenced in Makefile.am.
* Makefile.am: Tinkering to reduce .text size of minimum executable
from ~64K to ~47K.
* Renamed startup/exit.c to startup/bspclean.c
* startup/bspclean.c: New file.
* startup/exit.c: Removed.
* Makefile.am: Remove reference to ../../shared/main.c.
* Makefile.am: Include preinstall.am
* Makefile.am, README, bsp_specs, configure.ac,
console/lpc22xx_uart.h, console/uart.c, include/bsp.h,
network/network.c: New (Initial submission).
