Call bsp_work_area_initialize() before bsp_start(). This allows
bsp_start() to use malloc() etc. which is beneficial for systems with a
plug-and-play hardware enumeration.
Update #2408.
This section can be use to provide a cache coherent memory area via
rtems_cache_coherent_add_area().
Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC
into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to
figure out the code position given a fatal source and code.
Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS"
region. Move the region definition into the "linkcmds.base" files.
* include/lpc17xx.h: New file.
* Makefile.am, preinstall.am: Reflect change above. Update due to API
changes.
* configure.ac, console/console-config.c, include/bsp.h, include/io.h,
include/irq.h, include/lcd.h, include/lpc-clock-config.h,
include/lpc24xx.h, include/start-config.h, irq/irq-dispatch.c,
irq/irq.c, misc/bspidle.c, misc/io.c, misc/lcd.c, misc/restart.c,
misc/system-clocks.c, ssp/ssp.c, startup/bspreset.c,
startup/bspstart.c, startup/bspstarthooks.c,
startup/start-config-emc-dynamic.c, startup/start-config-emc-static.c,
startup/start-config-pinsel.c: Basic support for LPC17XX. New memory
configurations for W9825G2JB75I, IS42S32800B, and SST39VF3201.
* include/start-config.h, make/custom/lpc24xx_plx800_rom_int.cfg,
startup/linkcmds.lpc24xx_plx800_rom_int,
startup/start-config-pinsel.c: New files.
* Makefile.am, configure.ac, preinstall.am: Reflect changes above.
* startup/bspstarthooks.c: Use configuration tables for EMC
initialization.
* i2c/i2c-config.c: New file.
* include/lcd.h: Removed EMC definitions.
* misc/dma.c: Fixed initialization.
* include/i2c.h, include/io.h, include/lpc-ethernet-config.h,
include/lpc24xx.h, console/console-config.c, i2c/i2c.c, misc/io.c,
misc/lcd.c, startup/bspstart.c, startup/bspstarthooks.c: New pin
configuration API.
* Makefile.am, preinstall.am: Update.
* startup/linkcmds.lpc2362, startup/linkcmds.lpc23xx_tli800,
startup/linkcmds.lpc24xx_ea, startup/linkcmds.lpc24xx_ncs_ram,
startup/linkcmds.lpc24xx_ncs_rom_ext,
startup/linkcmds.lpc24xx_ncs_rom_int: Update due to linker command
file changes.
* include/lcd.h, misc/lcd.c: New files.
* misc/io.c, include/io.h: Documentation, bug fixes, more
configurations.
* include/lpc24xx.h: Added DAC and I2S.
* Makefile.am, bsp_specs, preinstall.am, startup/bspstarthooks.c,
file changes.
* make/custom/lpc23xx_tli800.cfg, startup/linkcmds.lpc23xx_tli800: New
files.
* Makefile.am, configure.ac: Reflect changes above.
* startup/linkcmds.lpc2362: Typos.
* README: Documentation.
* shared/include/start.h: Define start section attributes.
* include/lpc24xx.h, misc/dma-copy.c, misc/dma.c,
misc/system-clocks.c, ssp/ssp.c, startup/bspstarthooks.c: Removed
superfluous macros.
* Makefile.am, preinstall.am, include/bsp.h, startup/bspstart.c: Use
shared output character implementation.
* configure.ac: Add RTEMS_BSP_LINKCMDS.
* make/custom/lpc24xx.inc: Remove LDFLAGS.
* make/custom/lpc24xx_ea.cfg: Remove LPC24XX_LINKCMDS.
* make/custom/lpc24xx_ncs_ram.cfg: Remove LPC24XX_LINKCMDS.
* make/custom/lpc24xx_ncs_rom_ext.cfg: Remove LPC24XX_LINKCMDS.
* make/custom/lpc24xx_ncs_rom_int.cfg: Remove LPC24XX_LINKCMDS.
* startup/linkcmds: Remove.
* Makefile.am: Rework linkcmds handling.
* startup/linkcmds, startup/linkcmds.lpc2478,
startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram:
Fixed dummy entries.
