* | arm/lpc24xx: Remove include of <rtems/console.h> from <bsp.h> and fix warnings | Joel Sherrill | 2016-03-29 | 1 | -1/+0 |
* | arm/lpc24xx/include/bsp.h: Do not include <rtems/clockdrv.h> | Joel Sherrill | 2016-03-25 | 1 | -1/+0 |
* | bsps: Convert clock drivers to use a timecounter | Alexander Krutwig | 2015-05-20 | 1 | -0/+2 |
| | | | | Update #2271. | ||||
* | libchip/serial: Add alternative NS16550 driver | Sebastian Huber | 2014-10-07 | 1 | -5/+7 |
| | | | | Use the Termios device API. | ||||
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 13 | -13/+13 |
* | bsp/lpc24xx: Add LPC24XX_PIN_ETHERNET_POWER_DOWN | Pavel Pisa | 2014-03-14 | 1 | -0/+12 |
* | bsp/lpc24xx: Add lpc24xx_pin_get_first_index() | Sebastian Huber | 2014-03-14 | 1 | -0/+10 |
* | score: Add RTEMS_FATAL_SOURCE_BSP | Sebastian Huber | 2014-02-19 | 1 | -10/+0 |
| | | | | | | Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to figure out the code position given a fatal source and code. | ||||
* | bsp/lpc24xx: Add PL111 support | Sebastian Huber | 2014-01-10 | 1 | -0/+10 |
* | bsp/lpc24xx: Add register definition | Sebastian Huber | 2014-01-10 | 1 | -1/+3 |
* | doxygen: refactored doxygen in libbsp to illustrate new rule set | Daniel Ramirez | 2013-12-09 | 1 | -1/+1 |
* | bsp/lpc24xx: Fix register address | Sebastian Huber | 2013-04-08 | 1 | -1/+2 |
* | bsp/lpc24xx: Move UART probes to separate files | Sebastian Huber | 2013-02-11 | 1 | -1/+7 |
* | bsp/lpc24xx: Declare conditionally | Sebastian Huber | 2013-01-07 | 1 | -0/+4 |
* | bsp/lpc24xx: Add WWDT module defines | Sebastian Huber | 2013-01-07 | 1 | -1/+21 |
* | bsps/arm: Add interface down support | Sebastian Huber | 2012-12-18 | 1 | -0/+5 |
* | score: Add RTEMS_FATAL_SOURCE_EXIT | Sebastian Huber | 2012-11-15 | 1 | -10/+12 |
| | | | | | | | Include <bsp/default-initial-extension.h> in all BSPs. Call rtems_fatal() with RTEMS_FATAL_SOURCE_EXIT as source and the exit() status code as fatal code in every bsp_cleanup(). Move previous bsp_cleanup() code into bsp_fatal_extension(). | ||||
* | bsp/lpc24xx: Evaluate LPC17XX pin type | Sebastian Huber | 2012-10-12 | 1 | -3/+6 |
| | | | | New pin type LPC17XX_PIN_TYPE_OPEN_DRAIN. | ||||
* | Use proper 3 line form of license text | Joel Sherrill | 2012-10-11 | 1 | -2/+3 |
* | Revert "Add bspopts.h.in." | Gedare Bloom | 2012-08-06 | 1 | -115/+0 |
| | | | | | | | | | | | | This reverts commit daffa606cc4a45d93c1f0f4fe365fde0fda6acbb. Conflicts: c/src/lib/libbsp/arm/lpc24xx/include/bspopts.h.in c/src/lib/libbsp/powerpc/mpc55xxevb/include/bspopts.h.in c/src/lib/libbsp/powerpc/qoriq/include/bspopts.h.in Manually deleted conflicting files. | ||||
* | bsp/lpc24xx: More flexible region configuration | Sebastian Huber | 2012-06-15 | 1 | -1/+4 |
* | bsp/lpc24xx: Add lpc24xx_module_is_enabled() | Sebastian Huber | 2012-06-15 | 1 | -0/+2 |
* | bsp/lpc24xx: Ethernet support for LPC17XX | Sebastian Huber | 2012-06-15 | 1 | -9/+26 |
* | bsp/lpc24xx: Simplify EMC configuration | Sebastian Huber | 2012-06-15 | 1 | -0/+14 |
* | bsp/lpc24xx: New BSP variants (PLX800 on LPC1778) | Sebastian Huber | 2012-06-15 | 1 | -2/+2 |
* | Add bspopts.h.in. | Ralf Corsépius | 2012-05-24 | 1 | -0/+115 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 4 | -8/+0 |
* | bsp/lpc24xx: Fix define name | Sebastian Huber | 2012-04-23 | 1 | -1/+1 |
* | bsps/arm: Add BSP_ARMV7M_SYSTICK_PRIORITY | Sebastian Huber | 2012-04-07 | 1 | -0/+2 |
* | bsps/arm: Add BSP_ARMV7M_IRQ_PRIORITY_DEFAULT | Sebastian Huber | 2012-04-07 | 1 | -0/+2 |
* | bsps: Shared ARMv7-M interrupt support | Sebastian Huber | 2012-03-24 | 1 | -2/+0 |
* | bsps: Shared ARMv7-M clock driver | Sebastian Huber | 2012-03-24 | 1 | -0/+2 |
* | bsp/lpc24xx: More CAN pin definitions | Sebastian Huber | 2012-03-24 | 1 | -4/+16 |
* | Support for NXP LPC1700 family | Sebastian Huber | 2012-02-11 | 5 | -5/+167 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -4/+0 |
* | 2011-11-08 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-11-08 | 8 | -393/+1017 |
| | | | | | | | | | | | | | | | * include/lpc17xx.h: New file. * Makefile.am, preinstall.am: Reflect change above. Update due to API changes. * configure.ac, console/console-config.c, include/bsp.h, include/io.h, include/irq.h, include/lcd.h, include/lpc-clock-config.h, include/lpc24xx.h, include/start-config.h, irq/irq-dispatch.c, irq/irq.c, misc/bspidle.c, misc/io.c, misc/lcd.c, misc/restart.c, misc/system-clocks.c, ssp/ssp.c, startup/bspreset.c, startup/bspstart.c, startup/bspstarthooks.c, startup/start-config-emc-dynamic.c, startup/start-config-emc-static.c, startup/start-config-pinsel.c: Basic support for LPC17XX. New memory configurations for W9825G2JB75I, IS42S32800B, and SST39VF3201. | ||||
* | 2011-10-17 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-10-17 | 1 | -0/+98 |
| | | | | | | | | | | * include/start-config.h, make/custom/lpc24xx_plx800_rom_int.cfg, startup/linkcmds.lpc24xx_plx800_rom_int, startup/start-config-emc-dynamic.c, startup/start-config-emc-static.c, startup/start-config-pinsel.c: New files. * Makefile.am, configure.ac, preinstall.am: Reflect changes above. * startup/bspstarthooks.c: Use configuration tables for EMC initialization. | ||||
* | 2011-07-21 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-07-21 | 1 | -0/+18 |
| | | | | | * include/lpc24xx.h: Added ADC defines. * make/custom/lpc24xx.inc: Workaround for GCC bug 49641. | ||||
* | 2011-05-19 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-05-19 | 5 | -136/+705 |
| | | | | | | | | | | | * i2c/i2c-config.c: New file. * include/lcd.h: Removed EMC definitions. * misc/dma.c: Fixed initialization. * include/i2c.h, include/io.h, include/lpc-ethernet-config.h, include/lpc24xx.h, console/console-config.c, i2c/i2c.c, misc/io.c, misc/lcd.c, startup/bspstart.c, startup/bspstarthooks.c: New pin configuration API. * Makefile.am, preinstall.am: Update. | ||||
* | 2011-02-21 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-02-21 | 1 | -0/+2 |
| | | | | | | * misc/restart.c: New file. * Makefile.am: Reflect change from above. * include/bsp.h: Declare bsp_restart(). | ||||
* | 2010-12-03 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-12-03 | 3 | -0/+165 |
| | | | | | | | | | | | | | * include/lcd.h, misc/lcd.c: New files. * misc/io.c, include/io.h: Documentation, bug fixes, more configurations. * include/lpc24xx.h: Added DAC and I2S. * Makefile.am, bsp_specs, preinstall.am, startup/bspstarthooks.c, startup/linkcmds.lpc2362, startup/linkcmds.lpc23xx_tli800, startup/linkcmds.lpc24xx_ea, startup/linkcmds.lpc24xx_ncs_ram, startup/linkcmds.lpc24xx_ncs_rom_ext, startup/linkcmds.lpc24xx_ncs_rom_int: Update due to linker command file changes. | ||||
* | 2010-10-14 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-10-14 | 1 | -2/+0 |
| | | | | | * include/lpc24xx.h, misc/system-clocks.c: Removed superfluous include of <bsp/utility.h>. | ||||
* | 2010-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-20 | 1 | -0/+6 |
| | | | | | | * include/lpc24xx.h, misc/dma-copy.c, misc/dma.c, misc/system-clocks.c, ssp/ssp.c, startup/bspstarthooks.c: Removed superfluous macros. | ||||
* | 2010-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-20 | 1 | -0/+2 |
| | | | | | * Makefile.am, preinstall.am, include/bsp.h, startup/bspstart.c: Use shared output character implementation. | ||||
* | 2010-04-30 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-04-30 | 1 | -26/+0 |
| | | | | | | * include/irq-config.h: Removed file. * Makefile.am, preinstall.am: Reflect change above. * irq/irq.c: Removed superfluous parameter checks. | ||||
* | Changes throughout | Thomas Doerfler | 2010-04-09 | 1 | -0/+6 |
* | Fixed IO configurations | Thomas Doerfler | 2010-03-12 | 1 | -2/+2 |
* | add support for lpc32xx | Thomas Doerfler | 2010-01-12 | 3 | -209/+107 |
* | add missing files | Thomas Doerfler | 2009-12-16 | 1 | -0/+47 |
* | add support for LPC32xx | Thomas Doerfler | 2009-12-15 | 4 | -272/+283 |
