Update #3285.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* bsp_specs, start/start.S, startup/linkcmds: Use linker command base
file.
* start/start.S: Verify boot_card() is passed a NULL.
* Makefile.am: Update to current style.
* bsp_specs: Fix warning for _start.
* start/start.S: Proper attribution for origin.
* startup/bspstart.c: Add Skyeye bsp_reset() on Skyeye.
* include/.cvsignore: New file.
* include/bspopts.h.in: Removed.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, console/uarts.c, include/bsp.h, include/bspopts.h.in,
include/tm27.h, start/start.S, startup/bspstart.c, startup/linkcmds,
startup/memmap.c: New files.
* Makefile.am, README, configure.ac, preinstall.am, start/start.S,
startup/memmap.c: Add csb637 as alias and variant.
* startup/linkcmds.csb637: New file.
* start/start.S: Update for boot_card command line change.
* console/uarts.c, include/bsp.h, start/start.S, startup/bspstart.c,
startup/exit.c, startup/linkcmds: Correct license URL and/or fix
mistake in copyright notice. Both of these mistakes appear to be from
code submitted after these changes were made previously.
times, console/uarts.c, include/.cvsignore, include/bsp.h,
include/tm27.h, network/.cvsignore, network/network.c,
start/.cvsignore, start/start.S, startup/.cvsignore,
startup/bspstart.c, startup/exit.c, startup/linkcmds,
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, times,
console/uart.c, include/bsp.h, include/tm27.h, network/lan91c11x.c,
network/lan91c11x.h, network/network.c, start/start.S,
