These flags are obsolete with the EABI based ARM tool chain.
not updated.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Split BSP Idle Thread into separate file to follow convention
used on other BSPs.
Slight reformatting of file header comment block.
Add and use rtems_blkdev_request_done(). Block device transfer requests
must signal the completion status now with rtems_blkdev_request_done().
The return value of the block device IO control will be ignored for
transfer requests.
The first parameter of rtems_blkdev_request_cb is now the transfer
request structure.
Renamed rtems_blkdev_request::req_done to rtems_blkdev_request::done to
break third party drivers at compile time, otherwise this API change
would result in runtime errors.
Conflicts:
Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS"
region. Move the region definition into the "linkcmds.base" files.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
XXX
for details.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
PR 1917/bsps
* Makefile.am, console/uart.c: Modifications to add dynamic tables for
libchip serial drivers.
* startup/bspreset.c, startup/bspstart.c:
* gba/clock/clockdrv.c, gba/console/conio.c, gba/console/console.c,
gba/console/defaultfont.h, gba/include/arm_mode_bits.h,
gba/include/asm_macros.h, gba/include/bsp.h, gba/include/conio.h,
gba/include/gba.h, gba/include/gba_registers.h, gba/irq/irq.c,
gba/irq/irq.h, gba/startup/bspstart.c, gba/timer/timer.c,
gp32/include/bsp.h, gp32/startup/bspreset.c, gp32/startup/bspstart.c,
nds/tools/runtest, shared/comm/uart.c, shared/comm/uart.h,
smdk2410/include/bsp.h: Fix typo where license said
found in found in.
* start/start.S, startup/linkcmds: Use linker command base file.
* Makefile.am, preinstall.am: Added generic interrupt support modules.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* startup/bspstart.c: Interrupt support changes.
* csb336/make/custom/csb336.cfg,
csb337/make/custom/csb337.cfg, edb7312/make/custom/edb7312.cfg,
gba/make/custom/gba.cfg, gdbarmsim/make/custom/arm920.cfg,
gp32/make/custom/gp32.cfg, gumstix/make/custom/gumstix.cfg,
lpc32xx/make/custom/lpc32xx_phycore.cfg, nds/make/custom/nds.cfg,
rtl22xx/make/custom/rtl22xx.cfg, smdk2410/make/custom/smdk2410.cfg:
Use VFP floating point model.
* console/uart.c: Fix warnings.
* start/start.S: Verify boot_card() is passed a NULL.
* smc/smc.c: Replace EBADRQC with EINVAL.
