* | event.h: _Event_Manager_initialization no longer a static inline | Joel Sherrill | 1996-04-19 | 2 | -38/+0 |
* | event.h: _Event_Manager_initialization no longer a static inline | Joel Sherrill | 1996-04-19 | 4 | -0/+24 |
| | | | | support.h: updated to use RTEMS_APPLICATION macro | ||||
* | modified to generate fatal error when an unconfigured directive is invoked. | Joel Sherrill | 1996-04-19 | 12 | -4/+397 |
* | changes to compile in macro configuration without warnings. | Joel Sherrill | 1996-04-19 | 6 | -4/+48 |
* | *** empty log message *** | Joel Sherrill | 1996-03-21 | 3 | -8/+4 |
* | updated for 68302 and so gen68360 bsp would compile | Joel Sherrill | 1996-03-21 | 2 | -1/+13 |
* | update to reflect internal threads reorganization | Joel Sherrill | 1996-03-21 | 1 | -0/+22 |
* | Added 68360 support submitted by W. Eric Norum (eric@skatter.usask.ca). | Joel Sherrill | 1996-03-06 | 2 | -2/+12 |
| | | | | Also increased minimum stack size from 1K to 2K. | ||||
* | As part of reducing visibility into rtems and hiding the .inl files | Joel Sherrill | 1996-03-06 | 1 | -0/+1 |
| | | | | | from the application code, this file required more visibility than is given by default to application code. | ||||
* | Removed prototyes for static inline routines and moved the comments into | Joel Sherrill | 1996-03-06 | 158 | -6881/+2425 |
| | | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana. | ||||
* | Removed prototyes for static inline rgutines and moved the comments into | Joel Sherrill | 1996-03-06 | 1 | -41/+2 |
* | Changed io manager initialization routine to not be static and added it here. | Joel Sherrill | 1996-02-21 | 1 | -0/+37 |
* | Changed io manager initialization routine to not be static. | Joel Sherrill | 1996-02-21 | 1 | -0/+8 |
* | changed io manager initialization routine to not be static | Joel Sherrill | 1996-02-21 | 2 | -6/+2 |
* | Dispersal of internal thread handler resulted in the SYSI task being | Joel Sherrill | 1996-02-21 | 1 | -2/+2 |
| | | | | | | only required in a multiprocessor system. It was replace by the MPCI Receive Server. As a result, the CPU Table field for extra stack for the SYSI task was changed to be extra stack for the MPCI Receive Server. | ||||
* | Removed the internal thread objects and dispersed its contents to | Joel Sherrill | 1996-02-21 | 16 | -17/+778 |
| | | | | | | | | | | the thread handler (IDLE), MPCI object (SYSI now MP Receive) and initialize_executive_early (IO initialization). The SYSI task no longer exists in a single processor configuration. This reduces single processor Workspace requirements by a TCB and a stack which is often larger than the minimum stack size. Moving the IO initialization plus accompanying BSP hooks eliminated an initialization ordering problem in which a global task could be created before the MPCI was initialized. | ||||
* | Dispersal of internal thread handler resulted in IDLE thread becoming | Joel Sherrill | 1996-02-21 | 11 | -52/+49 |
| | | | | | part of the Thread Handler. This required the name of the optional CPU dependent IDLE thread implementation to change. | ||||
* | MPCI Receive became a thread and the prototype changed. | Joel Sherrill | 1996-02-21 | 1 | -1/+3 |
* | Removed the internal thread objects and dispersed its contents to | Joel Sherrill | 1996-02-21 | 1 | -12/+14 |
* | Removed arguments from _Thread_Start_multitasking. | Joel Sherrill | 1996-02-14 | 2 | -8/+2 |
* | idle thread now created before system initialization thread. | Joel Sherrill | 1996-02-14 | 1 | -4/+1 |
| | | | | Also system initialization thread only created in MP systems. | ||||
* | removed arguments from _Thread_Start_multitasking | Joel Sherrill | 1996-02-14 | 1 | -12/+10 |
* | white space problem | Joel Sherrill | 1996-02-14 | 1 | -1/+0 |
* | Moved some initialization from the system initialization thread to | Joel Sherrill | 1996-02-14 | 1 | -2/+42 |
| | | | | | initialize_executive_early. This was done to clear up an ordering problem in which global tasks could be created before the MPCI layer was initialized. | ||||
* | changed post task extension from user set to api set and added flag | Joel Sherrill | 1996-02-13 | 16 | -121/+76 |
| | | | | in each thread which must be set when the post switch extension is to be run. | ||||
* | added clear of _ISR_Signals_to_thread_executing | Joel Sherrill | 1996-02-13 | 1 | -1/+4 |
* | more comments added and existing ones cleaned up in synchronization paths | Joel Sherrill | 1996-02-13 | 1 | -1/+13 |
* | comma removed from end of last enumerated element | Joel Sherrill | 1996-02-13 | 2 | -2/+2 |
* | comment added to describe synchronization logic in timeout routine | Joel Sherrill | 1996-02-13 | 1 | -0/+21 |
* | *** empty log message *** | Joel Sherrill | 1996-02-12 | 1 | -4/+0 |
* | new isr synchronization algorithm using a single enumerated set of states. | Joel Sherrill | 1996-02-09 | 12 | -66/+110 |
* | added rtems_interrupt_is_in_progress | Joel Sherrill | 1996-02-09 | 2 | -0/+28 |
* | added clear of _ISR_Signals_to_thread_executing | Joel Sherrill | 1996-02-09 | 2 | -0/+2 |
* | changed synchronization algorithm to be a single list of enumerated states | Joel Sherrill | 1996-02-08 | 2 | -4/+4 |
* | alignment on workspace changed from CPU_ALIGNMENT to CPU_HEAP_ALIGNMENT | Joel Sherrill | 1996-02-08 | 2 | -2/+2 |
* | Swapped order of nested acquisition check and check for returning unsatisfied. | Joel Sherrill | 1996-02-01 | 1 | -6/+6 |
* | synchronization state bugs address | Joel Sherrill | 1996-02-01 | 1 | -7/+12 |
* | invalid use of tcb field resource count | Joel Sherrill | 1996-02-01 | 1 | -1/+0 |
* | added a task begin extension for unix simulator configurations. This extension | Joel Sherrill | 1996-01-19 | 1 | -0/+25 |
| | | | | insures that stdout is line buffered (see setvbuf). | ||||
* | changed version to 3.5.1 | Joel Sherrill | 1996-01-19 | 2 | -2/+2 |
* | added class to initial id macro | Joel Sherrill | 1996-01-17 | 4 | -16/+14 |
* | increased stack size | Joel Sherrill | 1996-01-17 | 1 | -1/+1 |
* | Split error handler into its own directory. | Joel Sherrill | 1996-01-15 | 1 | -1/+1 |
* | Made real body of _Heap_Walk conditional on RTEMS_DEBUG. This is necessary | Joel Sherrill | 1996-01-15 | 1 | -0/+13 |
| | | | | to be able to build a system without requiring printf. | ||||
* | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 1996-01-15 | 24 | -247/+354 |
* | changes remerged after lost in disk crash -- recovered from snapshot, ↵ | Joel Sherrill | 1995-12-20 | 14 | -105/+160 |
| | | | | partially recovered working tree, etc | ||||
* | changes remerged after disk crash -- history lost | Joel Sherrill | 1995-12-19 | 2 | -2/+2 |
* | changed version | Joel Sherrill | 1995-12-08 | 2 | -2/+2 |
* | added correct use of _Thread_queue_Enter_critical_section | Joel Sherrill | 1995-12-08 | 6 | -5/+6 |
* | Added comments for addition of is_fp flag to _CPU_Context_Initialize. | Joel Sherrill | 1995-12-05 | 1 | -0/+5 |
