* | moved from main include directory | Joel Sherrill | 1997-08-04 | 5 | -0/+478 |
* | Added these files to contain bodies for routines included in the API | Joel Sherrill | 1997-08-02 | 3 | -1/+102 |
| | | | | | but which did not have real bodies. This is necessary for languages like Ada95 which must have real entries in a library for bindings. | ||||
* | Katsutoshi Shibuya (shibuya@mxb.meshnet.or.jp)of BU-Denken Co., Ltd. | Joel Sherrill | 1997-08-01 | 2 | -0/+191 |
| | | | | | | | (Sapporo, Japan) submitted the extended console driver for the MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines. This device driver supports four serial ports, cooked IO, and provides a portable base for Zilog 8530 based console drivers. | ||||
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 1 | -2/+55 |
| | | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | ||||
* | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1997-07-31 | 6 | -30/+139 |
* | Added comment to indicate what the commented out C_PIECES indicated. | Joel Sherrill | 1997-07-31 | 1 | -2/+3 |
* | fixed typo | Joel Sherrill | 1997-07-18 | 2 | -8/+8 |
* | Strip the trace bit from the SR register when dispatching a thread when | Joel Sherrill | 1997-07-10 | 1 | -3/+5 |
| | | | | | exiting from an ISR. This allows the trace bit to be set on a per task basis and tracing to be limited to that task. | ||||
* | Repository damaged -- files readded. | Joel Sherrill | 1997-07-09 | 2 | -0/+411 |
* | Changed name from entry to thread_entry to be more compatible with | Joel Sherrill | 1997-07-09 | 3 | -3/+3 |
| | | | | Ada interface where entry is a keyword. | ||||
* | Added postswitch extension. | Joel Sherrill | 1997-07-09 | 2 | -0/+4 |
* | Added post switch extension. | Joel Sherrill | 1997-07-09 | 2 | -0/+10 |
* | Corrected typos and spacing. | Joel Sherrill | 1997-07-09 | 2 | -6/+6 |
* | Added sp, sfc, and fpcsr register defines. | Joel Sherrill | 1997-07-09 | 1 | -0/+4 |
* | Added support for context switching the data used by the gcc m68k | Joel Sherrill | 1997-05-28 | 6 | -3/+111 |
| | | | | | | software floating point emulation code. Code implemented by Karen Sara Looney <Karen.Looney@colorado.edu> with much email assistance from Joel. | ||||
* | changed version number to 4.1.0. | Joel Sherrill | 1997-05-27 | 2 | -2/+2 |
* | Corrected by adding check for NULL address passed into get_status | Joel Sherrill | 1997-04-25 | 1 | -0/+3 |
| | | | | directive. | ||||
* | Added to comment header block to include new status directive. | Joel Sherrill | 1997-04-25 | 2 | -0/+2 |
* | Patch from Chris John <cjohns@awa.com.au> to add use of a select statement | Joel Sherrill | 1997-04-22 | 5 | -3/+180 |
| | | | | | | in the unix port idle thread task. This should keep the entire application from blocking when any component does a blocking application. Also added TOD_MICROSECONDS_TO_TICKS. | ||||
* | promote TOD_MICROSECONDS_TO_TICKS through API as RTEMS_MICROSECONDS_PER_TICK. | Joel Sherrill | 1997-04-22 | 2 | -0/+4 |
* | multiprocessing fixed on linux by fixing cpu.c so correct form of | Joel Sherrill | 1997-04-22 | 1 | -3/+4 |
| | | | | semctl was being invoked. | ||||
* | updated with new license information per Tony Bennett. | Joel Sherrill | 1997-04-22 | 7 | -72/+22 |
* | File changed to reflect change in license and copyright. | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 476 | -2354/+2354 |
* | Added FPSP support for MC68040 | Joel Sherrill | 1997-04-16 | 3 | -5/+71 |
* | Reduced number of POSIX thread priorities from 255 to 254 to avoid conflicts | Joel Sherrill | 1997-04-15 | 4 | -8/+20 |
| | | | | | of lowest priority with the RTEMS IDLE thread. This was causing the lowest priority GNAT Ada task to never run. | ||||
* | added code to prevent attempts to clean up the library when rtems is | Joel Sherrill | 1997-04-09 | 1 | -0/+8 |
| | | | | down. | ||||
* | added support for tracking thread cpu usage. | Joel Sherrill | 1997-04-09 | 1 | -0/+2 |
* | enhanced printf statements | Joel Sherrill | 1997-04-09 | 1 | -4/+4 |
* | corrected spacing. | Joel Sherrill | 1997-04-09 | 2 | -16/+16 |
* | added SYSTEM_STATE_SHUTDOWN | Joel Sherrill | 1997-04-09 | 2 | -0/+2 |
* | enhanced rtems_shutdown_executive to insure that no attempt will | Joel Sherrill | 1997-04-09 | 1 | -1/+4 |
| | | | | be made to shut the system down when it is down. | ||||
* | added support for statistics on rate monotonic periods. | Joel Sherrill | 1997-04-09 | 3 | -15/+142 |
* | Added ka9q tcpip stack and network driver for the gen68360. This effort | Joel Sherrill | 1997-04-09 | 14 | -19/+228 |
| | | | | | | | | | | | | | was done based on the 3.6.0 release and had to be autoconf'ed locally. It is turned on is the bsp enables it and it is not explicitly disabled via the configure option --disable-tcpip. As many warnings as possible were removed locally after the code was merged. Only the gen68360 and mvme136 bsps were compiled this way. The ka9q port and network driver were submitted by Eric Norum (eric@skatter.USask.Ca). The network demo programs are not included in the tree at this point. | ||||
* | removed noreturn attribute to eliminate warnings. | Joel Sherrill | 1997-04-07 | 1 | -2/+7 |
* | added initialization of variable to eliminate warning. | Joel Sherrill | 1997-04-07 | 1 | -1/+1 |
* | added ifdef around variables to eliminate warnings when cross | Joel Sherrill | 1997-04-07 | 1 | -0/+2 |
* | added "ifndef" to avoid redefinition warning. | Joel Sherrill | 1997-04-07 | 2 | -0/+4 |
* | added volatile to Switch_necessary structure member to avoid warning. | Joel Sherrill | 1997-04-07 | 1 | -2/+2 |
* | added test to avoid spurious error | Joel Sherrill | 1997-04-07 | 1 | -1/+1 |
* | added prototype for missing routine. | Joel Sherrill | 1997-04-07 | 1 | -0/+4 |
* | added "return" to eliminate warning. | Joel Sherrill | 1997-04-07 | 1 | -0/+2 |
* | added "ifndef" to avoid redefinition warning | Joel Sherrill | 1997-04-07 | 5 | -0/+10 |
* | added prototypes for two assembly language routines to eliminate warnings. | Joel Sherrill | 1997-04-07 | 1 | -0/+9 |
* | commented out sccs_id to eliminate warning. | Joel Sherrill | 1997-04-07 | 4 | -12/+26 |
* | added plea for someone to implement software stack switching for m68000-ish | Joel Sherrill | 1997-04-07 | 1 | -0/+3 |
| | | | | cores. | ||||
* | Replaced warning message for cpus which do not have hardware support | Joel Sherrill | 1997-04-07 | 1 | -2/+3 |
| | | | | | for an interrupt stack. Hopefully this will encourage someone to implement software stack switching on the m68k. | ||||
* | initialized variable to eliminate warning | Joel Sherrill | 1997-04-07 | 1 | -1/+3 |
* | changed signed int to unsigned to eliminate warning | Joel Sherrill | 1997-04-07 | 1 | -1/+1 |
* | added "ifndef" for ASM to avoid redefinition warnings. | Joel Sherrill | 1997-04-07 | 1 | -0/+2 |
