path: root/c/src/exec/score/cpu (follow)
* 2001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-038-133/+18
| | | | | | | * Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/mipstypes.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
* 2001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-031-0/+7
| | | | | | | * Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/m68ktypes.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
* 2001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-034-59/+9
| | | | | | | * Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/i960types.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
| | | | | | | * Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/i386types.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
* 2001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-034-48/+9
| | | | | | | * Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/hppa1.1types.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
* 2001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-034-58/+9
| | | | | | | * Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/h8300types.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
| | | | | | | * Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/c4xtypes.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
* 2001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-038-115/+18
| | | | | | | * Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/a29ktypes.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
* 2002-03-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-292-32/+10
| | | | | | | | * cpu.c: Replace NO_TABLE_MOVE-support by external function (code moved to libcpu/sparc/tbr/tbr.c). * cpu.h: Replace NO_TABLE_MOVE-support by external function (code moved to libcpu/sparc/tbr/tbr.h). * sparc.h: Add sparc_init_tbr (implemented in libcpu/sparc/tbr/tbr.c).
* 2001-03-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-282-0/+7
| | | | * cpu.c: Define fix_syscall_errno() to nothing so MP links.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2851-51/+153
| | | | | | | | | * cpu/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-20 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-03-202-0/+11
| | | | * cpu_asm.S: Now compiles on 4600 and 4650.
* 2002-03-13 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-03-153-24/+42
| | | | | | * cpu_asm.S: Fixed a sneaky return from int w/ ints disabled bug. * rtems/score/cpu.h: Fixed register numbering in comments and made interrupt enable/disable more robust.
* 2002-03-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-152-1/+5
| | | | * rtems/score/m68k.h: m68k_swap_u32 fix typo.
* 2002-03-05 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-03-086-49/+268
| | | | | | | | | | | | * cpu_asm.S: Added support for the debug exception vector, cleaned up the exception processing & exception return stuff. Re-added EPC in the task context structure so the gdb stub will know where a thread is executing. Should've left it there in the first place... * idtcpu.h: Added support for the debug exception vector. * cpu.c: Added ___exceptionTaskStack to hold a pointer to the stack frame in an interrupt so context switch code can get the userspace EPC when scheduling. * rtems/score/cpu.h: Re-added EPC to the task context.
* 2002-03-06 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2002-03-062-0/+39
| | | | | | * rtems/score/m68k.h [M68K_COLDFIRE_ARCH] (CPU_swap_u16, CPU_swap_u32): Generic implementation of endian swap primitives added for Coldfire family.
* 2002-02-27 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-03-016-124/+281
| | | | | | | | | | | | | | | | * cpu_asm.S: Fixed exception return address, modified FP context switch so FPU is properly enabled and also doesn't screw up the exception FP handling. * idtcpu.h: Added C0_TAR, the MIPS target address register used for returning from exceptions. * iregdef.h: Added R_TAR to the stack frame so the target address can be saved on a per-exception basis. The new entry is past the end of the frame gdb cares about, so doesn't affect gdb or cpu.h stuff. * rtems/score/cpu.h: added an #ifdef so cpu_asm.S can include it to obtain FPU defines without systax errors generated by the C defintions. * cpu.c: Improved interrupt level saves & restores.
* 2001-02-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-272-1/+5
| | | | * rtems/score/cpu.h: Fix conditional to match current GCC.
* 2002-02-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-02-132-8/+4
| | | | * configure.ac: Fix the test to determine cpu context size.
* 2002-02-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-083-153/+163
| | | | | * iregdef.h, rtems/score/cpu.h: Reordered register in the exception stack frame to better match gdb's expectations.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-054-16/+227
| | | | | | | | | * cpu_asm.S: Enhanced to save/restore more registers on exceptions. * rtems/score/cpu.h (CPU_Interrupt_frame): Enhanced to list every register individually and document when it is saved. * idtcpu.h: Added constants for the coprocessor 1 registers revision and status.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-052-0/+5
| | | | * .cvsignore: Added stamp-h.in.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-0512-35/+16
| | | | * rtems/Makefile.am, rtems/score/Makefile.am: Removed again.
* 2001-02-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-042-1/+6
| | | | | * rtems/score/cpu.h: IDLE task should not be FP. This was a mistake in the previous patch that has now been confirmed.
* 2001-02-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-042-3/+6
| | | | | * configure.ac: Removed references to rtems/Makefile and rtems/score/Makefile.
* 2001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-02-014-148/+244
| | | | | | | | | * cpu.c: Enhancements and fixes for modifying the SR when changing the interrupt level. * cpu_asm.S: Fixed handling of FP enable bit so it is properly managed on a per-task basis, improved handling of interrupt levels, and made deferred FP contexts work on the MIPS. * rtems/score/cpu.h: Modified to support above changes.
* 2002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-02-012-11/+26
| | | | * Makefile.am: Reflect 2002-01-23 changes.
* 2002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-313-26/+31
* 2002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-313-29/+31
| | | | | | | * rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. * Makefile.am: Reflect changes above.
* 2001-01-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-302-3/+20
| | | | * Makefile.am: Corrected so .h files from rtems/score/ are installed.
* 2002-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-3029-226/+146
* 2002-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-3025-273/+184
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-3015-161/+103
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-302-8/+21
| | | | * Makefile.am: Reflect changes from 2002-01-23.
* 2002-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-244-39/+9
| | | | | | | * rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. AC_CONFIG_SRCDIR(asm.h).
* 2002-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-248-78/+14
* 2002-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-247-57/+63
| | | | | | | | | | | * Makefile.am: Merge in rtems/Makefile.am and rtems/score/Makefile.am. Remove gensize. Require automake-1.5. * rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * rtems/score/.cvsignore: Add unixsize.h*. Add stamp-h*. * configure.ac: Add AM_CONFIG_HEADER(rtems/score/unixsize.h). * rtems/score/cpu.h: Replace CPU_CONTEXT_SIZE_IN_BYTES with SIZEOF_CPU_CONTEXT.
* 2002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-2210-1159/+60
| | | | | | | | | | | | | | | | | * rtems/Makefile.am: New. * rtems/.cvsignore: New. * rtems/score/Makefile.am: New. * rtems/score/.cvsignore: New. * rtems/score/ppc.h: Relocated from shared/. * rtems/score/ppctypes.h: Relocated from shared/. * asm.h: Relocated from shared/. * shared/Makefile.am: Removed. * shared/asm.h: Removed. * shared/ppc.h: Removed. * shared/ppctypes.h: Removed. * shared/.cvsignore: Removed. * Makefile.am: Reflect changes above. * configure.ac: Reflect changes above.
* 2002-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-162-1/+8
| | | | | * asm.h: Remove #include <rtems/score/targopts.h>. Add #include <rtems/score/cpuopts.h>.
* 2002-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-163-4/+8
| | | | | | * asm.h: Remove #include <rtems/score/targopts.h>. Add #include <rtems/score/cpuopts.h>. * configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP(RTEMS_BSP).
* 2002-01-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-082-0/+6
| | | | * rtems/score/cpu.h: #include <rtems/bspIo.h>.
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-064-6/+8
| | | | * configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* 2002-01-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-064-2/+10
| | | | * cpu.c: Include rtems/bspIo.h instead of bspIo.h.
* 2001-12-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-206-3/+15
| | | | * configure.ac: Use RTEMS_ENV_RTEMSCPU.
* 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-1932-45/+109
| | | | * Makefile.am: Add multilib support.
* 2001-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-183-2/+7
| | | | | * asm.h: include cpuopts.h instead of targopts.h * rtems/score/arm.h: Use __arm__.
* 2001-11-28 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-2832-0/+231
| | | | | | | This was tracked as PR91. * rtems/score/cpu.h: Added CPU_PROVIDES_ISR_IS_IN_PROGRESS macro which is used to specify if the port uses the standard macro for this (FALSE). A TRUE setting indicates the port provides its own implementation.
* 2001-11-28 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-282-0/+14
| | | | | | | | | | This was tracked as PR91. * rtems/score/cpu.h: Added CPU_PROVIDES_ISR_IS_IN_PROGRESS macro which is used to specify if the port uses the standard macro for this (FALSE). A TRUE setting indicates the port provides its own implementation. * rtems/score/c_isr.inl: Deleted and contents merged into cpu.c. * cpu.c: Received contents of c_isr.inl. * Makefile.am: Deleted reference to c_isr.inl.
