* rtems/score/cpu_asm.h: Enhanced to include register offsets.
* Makefile.am: Install rtems/score/cpu_asm.h.
* cpu.c: Significantly enhanced including the implementation of
_CPU_ISR_Get_level.
* cpu_asm.S: Improved behavior of context switch and interrupt
dispatching.
* rtems/score/arm.h: Improved the CPU model name determination.
* rtems/score/cpu.h: Improved interrupt disable/enable functions.
* cpu_asm.S: Added SR_IEO to context restore to fix isr disabled
deadlock caused by interrupt arriving while dispatching.
* cpu.c, irq.c, rtems/score/cpu.h: Filled in something that was
marked XXX.
* rtems/score/cpu.h: Filled in something that was marked XXX.
* Makefile.am: Remove reference to deprecated rtems.c.
* rtems.c: Remove.
* rtems.c: Remove.
* rtems.S: Remove.
* rtems/score/cpu.h: Fixed comments and renamed
CPU_SYSTEM_INITIALIZATION_THREAD_EXTRA_STACK to
CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK to be consistent with other code.
* Makefile.am, cpu.c, cpu_asm.S, rtems.S: Modified to make
this all compile again. It has been a while since we have
had a semi-working hppa1.1-rtems cross compiler. :)
* configure.ac: Add RTEMS_PROG_CCAS
* configure.ac: Use AC_CONFIG_AUX_DIR(../../../..).
Add AC_PROG_RANLIB.
* configure.ac: Remove references to RTEMS_BSP.
* Include $(top_srcdir)/automake/*.am.
* Makefile.am: Include $(top_srcdir)/../../../automake/*.am.
Use ../../../aclocal.
* rtems/score/m68k.h: Per PR227, mc68060 does not require FPSP
since it is now multilib'ed.
* rtems/score/ppc.h: Remove PPC_DEBUG_MODEL.
* rtems/new-exceptions/cpu.h: Per PR211 fix
saving/restoring floating point context. The fpsave and fprestore
routines are only used in a executing context which _is_ fp and hence
has the FPU enabled. The current behavior required the FPU always to
be on which is very dangerous if lazy context switching is used.
[Joel Note: Some ports explicitly enabled the FPU in the FP save and
restore routines to avoid this.]
The patch also makes sure (on powerpc only) that the FPU is disabled
for integer tasks. Note that this is crucial if deferred fp context
switching is used. Otherwise, fp context corruption may go undetected!
Also note that even tasks which merely push/pop FP registers to/from
the stack without modifying them still MUST be FP tasks - otherwise
(if lazy FP context switching is used), FP register corruption (of
other, FP, tasks may occur)!
Furthermore, (on PPC) by default, lazy FP context save/restore
is _disabled_.
* rtems/powerpc/registers.h, rtems/score/ppc.h: Per PR213, add
support for the MPC74000 (AKA G4); there is no AltiVec support yet,
however.
* rtems/score/ppc.h: Remove rtems_multilib.
Add mpc555 (Based on comments from Sergei Organov <osv@javad.ru>).
* rtems/old-exceptions/cpu.h: Remove _CPU_Data_Cache_Block_Flush.
Remove _CPU_Data_Cache_Block_Invalidate.
* asm.h: Use cpuopts.h instead of targopts.h.
* rtems/score/hppa.h: Remove rtems/score/targopts.h.
* asm.h: Include cpuopts.h instead of targopts.h.
* rtems/new-exceptions/cpu.h: Relocated from
libbsp/powerpc/support/new_exception_processing/rtems/score/cpu.h
* rtems/old-exceptions/cpu.h: Relocated from
c/src/lib/libbsp/powerpc/support/old_exception_processing/rtems/score/cpu.h
* rtems/powerpc/registers.h: Relocated and renamed from
libcpu/powerpc/shared/include/cpu.h.
* rtems/score/cpu.h: New.
* rtems/score/cpu.h (CPU_ISR_Disable and CPU_ISR_Enable): Correct them
where they correctly inform the compiler about the register they
are modifying.
* rtems/score/idtr.h: New file, extracted from libcpu/cpu.h.
* rtems/score/interrupts.h: New file, extracted from libcpu/cpu.h.
* rtems/score/registers.h: New file, moved from libcpu.
* cpu.c: Don't include cpuModel.h,
#include <rtems.h>,
#include <rtems/score/i386types.h>,
#include <rtems/score/idtr.h>.
* rtems/score/cpu.h: Don't include libcpu/cpu.h.
#include <rtems/score/interrupts.h>,
#include <rtems/score/registers.h>.
* rtems.c: Adaptation to gcc-3.0.x.
* cpu.c: Remove call to sparc_init_tbr/NO_TABLE_MOVE.
* rtems/score/cpu.h: Remove NO_TABLE_MOVE conditional code.
* include/rtems/score/ispsh7750.h, score/ispsh7750.c: Account for
name change.
* rtems/score/cpu.h: Account for name change.
* rtems/score/unixtypes.h: Removed.
* rtems/score/types.h: New file via CVS magic.
* Makefile.am, rtems/score/cpu.h: Account for name change.
* rtems/score/sparctypes.h: Removed.
* rtems/score/shtypes.h: Removed.
* rtems/score/ppctypes.h: Removed.
* rtems/score/or32types.h: Removed.
* rtems/score/or16types.h: Removed.
* rtems/score/no_cputypes.h: Removed.
* rtems/score/mipstypes.h: Removed.
* rtems/score/m68ktypes.h: Removed.
* rtems/score/i960types.h: Removed.
* rtems/score/i386types.h: Removed.
* rtems/score/hppa1.1types.h: Removed.
* rtems/score/h8300types.h: Removed.
* rtems/score/c4xtypes.h: Removed.
* rtems/score/a29ktypes.h: Removed.
* cpu.c: Replace NO_TABLE_MOVE-support by external function
(code moved to libcpu/sparc/tbr/tbr.c).
* cpu.h: Replace NO_TABLE_MOVE-support by external function
(code moved to libcpu/sparc/tbr/tbr.h).
* sparc.h: Add sparc_init_tbr (implemented in libcpu/sparc/tbr/tbr.c).
* cpu.c: Define fix_syscall_errno() to nothing so MP links.
* cpu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
