* | Modified a lot of files to take a first cut at supporting building from | Joel Sherrill | 1997-12-10 | 1 | -1/+4 | |
| | | | | | any directory in the build tree. The only variable which must be set before the command "gmake" is invoked is RTEMS_BSP (e.g. RTEMS_BSP=erc32). | |||||
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 7 | -14/+14 | |
* | Removed include directory at "build" point and the link of this directory | Joel Sherrill | 1997-10-08 | 1 | -4/+4 | |
| | | | | | | to lib/include. Went to using a PROJECT_INCLUDE variable. | |||||
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 7 | -35/+35 | |
| | | | | of switching to the modified GNU GPL. | |||||
* | Added ka9q tcpip stack and network driver for the gen68360. This effort | Joel Sherrill | 1997-04-09 | 1 | -0/+9 | |
| | | | | | | | | | | | | | was done based on the 3.6.0 release and had to be autoconf'ed locally. It is turned on is the bsp enables it and it is not explicitly disabled via the configure option --disable-tcpip. As many warnings as possible were removed locally after the code was merged. Only the gen68360 and mvme136 bsps were compiled this way. The ka9q port and network driver were submitted by Eric Norum (eric@skatter.USask.Ca). The network demo programs are not included in the tree at this point. | |||||
* | added "ifndef" to avoid redefinition warning. | Joel Sherrill | 1997-04-07 | 1 | -0/+2 | |
* | This set of changes is the build of what was required to convert to | Joel Sherrill | 1997-04-01 | 1 | -0/+74 | |
| | | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. | |||||
* | Removed defines now handled by targopts.h. | Joel Sherrill | 1997-01-29 | 1 | -22/+0 | |
* | Added include of rtems/score/cpu.h | Joel Sherrill | 1997-01-29 | 1 | -1/+0 | |
* | Added include of targopts.h. | Joel Sherrill | 1997-01-29 | 1 | -1/+1 | |
* | Changes to reflect new revision of erc32 per Jiri Gaisler's suggestions. | Joel Sherrill | 1996-12-02 | 4 | -19/+35 | |
| | | | | This is current as of sis 2.6. | |||||
* | patches to erc32.h to correct handling of timer mirror from Jiri Gaisler. | Joel Sherrill | 1996-10-14 | 1 | -3/+3 | |
* | use address object to avoid direct pointer arithmetic | Joel Sherrill | 1996-09-18 | 1 | -1/+1 | |
* | ERC32_Force_interrupt implementation replaced per Jiri Gaisler's experience | Joel Sherrill | 1996-08-08 | 1 | -0/+5 | |
| | | | | on the real erc32 hardware. | |||||
* | added 3 nops following write to wim since a restore following it is | Joel Sherrill | 1996-08-01 | 1 | -0/+3 | |
| | | | | subject to causing unpredictable window underflow/overflows. | |||||
* | split the inclusion of "EXTERN" data based on whether it was sapi, | Joel Sherrill | 1996-05-28 | 1 | -5/+5 | |
| | | | | score, rtems api, or posix api related. | |||||
* | added stack allocation fields to the cpu table | Joel Sherrill | 1996-04-22 | 1 | -6/+4 | |
* | Dispersal of internal thread handler resulted in IDLE thread becoming | Joel Sherrill | 1996-02-21 | 2 | -10/+10 | |
| | | | | | part of the Thread Handler. This required the name of the optional CPU dependent IDLE thread implementation to change. | |||||
* | added clear of _ISR_Signals_to_thread_executing | Joel Sherrill | 1996-02-13 | 1 | -1/+4 | |
* | increased stack size | Joel Sherrill | 1996-01-17 | 1 | -1/+1 | |
* | typos fixed | Joel Sherrill | 1995-10-31 | 8 | -8/+105 | |
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 9 | -740/+2014 | |
* | SPARC merged and successfully tested w/o interrupt support | Joel Sherrill | 1995-10-06 | 7 | -0/+1866 | |
