this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
mips64orion/cpu_asm.h
mips64orion/mips64orion.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
> 3) rtems-rc-19990131-2.diff
> now)
> patches will apply then ;-.
To achieve this:
been removed.
getting the spurious trap handling to work required a couple more
fixes - I have attached a patch against rtems-4.0.0 with the
necessary changes. I also added functionality so that the
address of the trapped instruction is reported and in case of
a data access error, the data address is also reported.
> > I think I have found a bug in src/exec/scor/sparc/cpu/erc32.h in:
> > #define ERC32_Disable_interrupt( _source, _previous ) \
> > do { \
> > unsigned32 _level; \
> > unsigned32 _mask = 1 << (_source); \
> > sparc_disable_interrupts( _level ); \
> > (_previous) = ERC32_MEC.Interrupt_Mask; \
> > ERC32_MEC.Interrupt_Mask = _previous | _mask; \
> > sparc_enable_interrupts( _level ); \
> > (_previous) &= ~_mask; \ <- IS THIS CORRECT...?
> > } while (0)
> > The previous interrupt mask is returned after first clearing the
> > bit to be disabled, regardless whether the bit was set before or
> > not. If the bit was set (interrupt masked), subsequent call to
> > ERC32_Restore_interrupt() will enable the interrupt even though
> > it was supposed to be masked. This is indeed what happens in
> > DEBUG_puts when polled console I/O is used. In my opinion, the
> > last statement in the macro should be removed - what is your opinion?
> I think the "~" shouldn't be there. I recall that the intent of that line
> is to only return the state of the interrupts you were concerned with.
> Removing the line returns entire state. Given that the value returned
> shuold only be used in conjunction with the map, I suppose either removing
> the ~ or the entire line is correct? I can go either way. Just let me
> know which you think is more correct and the source will change. :)
Hmmm, just removing the '~' should be OK. DEBUG_puts() seems to be the
only user of ERC32_Restore_interrupt() anyway ...
ports.
old way of setting th cpu family and model string names.
vector number to user ISR's and other ports could pass both the vector
number and a pointer to the ISF.
external interrupt priorities were not being honored. Here is some
of his original report:
using rtems/erc32, I have a problem with interrupt priority when
interrupts occure simultaneously. Erc32 has an interrupt force
register where interrupts can be generated. If more than one
interrupt is generated, the interrupt handlers are scheduled in
the wrong order, i.e. with the lowest priority first.
I have attched a program that generates three interrupts, 0x11, 0x12
and 0x13. Interrupt 0x13 should be handled first, but is actually
handled last. Below is the output from sis:
sis> go
resuming at 0x02000000
RAM size: 4096 K, ROM size: 2048 K
Watchdog disabled
Waitstates = RAM read: 0, RAM write: 0, ROM read: 0, ROM write: 0
Power-down mode enabled
infinite UART baudrate
External interrupt received with vector 0x11
External interrupt received with vector 0x12
External interrupt received with vector 0x13
I have verified that sis generates the interrupts in the correct
order, i.e. 0x13 first, then 0x12 and then 0x11. So the problem
seems to be in the rtems interrupt handler. Do you use the PIL field
in the %psr register to mask lower priority interrupts or are all
external interrupts considered to have the same priority ..?
Here is a description of the fix:
it turned out that lower priority interrupts were not at all masked
off during interrupt handling. I made the following fix to cpu_asm.s:
... fix is in the code ...
There might be a simpler way of doing this, but this works...
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
was done based on the 3.6.0 release and had to be autoconf'ed locally.
It is turned on is the bsp enables it and it is not explicitly disabled
via the configure option --disable-tcpip. As many warnings as possible
were removed locally after the code was merged. Only the gen68360
and mvme136 bsps were compiled this way.
The ka9q port and network driver were submitted by Eric Norum
(eric@skatter.USask.Ca).
The network demo programs are not included in the tree at this point.
be resolved.
This is current as of sis 2.6.
on the real erc32 hardware.
subject to causing unpredictable window underflow/overflows.
part of the Thread Handler. This required the name of the optional
CPU dependent IDLE thread implementation to change.
