This was tracked as PR91.
_Interrupt_Manager_initialization.
bugs.
rm -rf c/src/exec/score/cpu/a29k/wrap
rm -rf c/src/exec/score/cpu/hppa1.1/wrap
rm -rf c/src/exec/score/cpu/i386/wrap
rm -rf c/src/exec/score/cpu/mips64orion/wrap
rm -rf c/src/exec/score/cpu/no_cpu/wrap
patch -p1 < rtems-rc-19991123-rc-2.diff.gz
* I don't see a possiblity to convert the powerpc subdirectory in its
current layout to automake the time being.
* Besides the fact that this subdirectory is not in single-tree building
layout, the actual showstopper is the ifeq $(RTEMS_CPU_MODEL),mpc750)
gmake-conditional in powerpc/Makefile.in, which automake (correctly)
refuses to handle.
* The problem is *not* specific to the powerpc. Other CPUs basically
have similar problems (SH:sh7032 vs sh7045, SPARC: erc32.h in
score/cpu/sparc), but have been lucky to get around real issues (cf.
configuration files below score/cpu/sh/).
* From a configuration focused POV this problem boils down to a
file/subdirectory selection problem:
ppc: 1 or others
sh: 1 out of 2
sparc: 1 out of 1
Automake's means to implement such behavior is using conditionals to be
evaluated at configuration-time. The old configuration scheme however
used make-time conditionals. The SH port was lucky to get around this
issue because it applies a selection from a limited set of possible
selections, the powerpc however applies a selection from an unlimited
set, based on data not being available at configuration time.
* Currently I only see two general solutions:
1) make RTEMS_CPU_MODEL available at configuration time, ie. replace
make-time configuration by configuration-time configuration
2) Perform the selection at build-time, i.e. always install all files,
but use #ifdef #else #endif in source files. This is what the m68k has
exploited at other locations inside of the source-tree.
=> This directory is the last one remaining not using automake below the
whole exec/ hierarchy.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
BSP needs to be eliminated.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
mips64orion/cpu_asm.h
mips64orion/mips64orion.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
