when building the executive source.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
be made to shut the system down when it is down.
table.
be resolved.
it was necessary to include system.h before checking if anything was
defined.
deleted a blank line in rtemsapi.c
the thread handler (IDLE), MPCI object (SYSI now MP Receive)
and initialize_executive_early (IO initialization). The SYSI task
no longer exists in a single processor configuration. This reduces
single processor Workspace requirements by a TCB and a stack which
is often larger than the minimum stack size. Moving the IO initialization
plus accompanying BSP hooks eliminated an initialization ordering problem
in which a global task could be created before the MPCI was initialized.
Also system initialization thread only created in MP systems.
initialize_executive_early. This was done to clear up an ordering problem
in which global tasks could be created before the MPCI layer was initialized.
like signal dispatching.
+ Added name pointer to Object_Control.
+ Modified Object Open and Close to address name field.
+ Removed name as separate element from Thread and Proxy Control.
+ Added parameter "object class" to calls to Initialize Information
+ variable length messages
+ named devices
+ debug monitor
