path: root/c/src/exec/configure.ac (follow)
* 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-051-1/+1
| | | | * configure.ac: RTEMS_TOP(..).
* 2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-011-2/+0
| | | | | * configure.ac: Remove RTEMS_PROJECT_ROOT. * aclocal/project-root.m4: Remove.
* 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-271-1/+1
| | | | * configure.ac: Use AC_CONFIG_AUX_DIR(..).
* 2002-06-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-261-3/+3
| | | | | | | | * configure.ac: Remove references to RTEMS_BSP. * aclocal/check-multiprocessing.m4: Remove references to RTEMS_BSP. Allow building w/ --enable-multiprocessing --enable-multilib. * aclocal/enable-multiprocessing.m4: Eliminate RTEMS_HAS_MULTIPROCESSING.
* 2002-06-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-251-1/+2
| | | | | | | * configure.ac: Add librpc. AC_PROG_RANLIB. * wrapup/Makefile.am: Add librpc. Use relative path to lib*.a for POSIX_OBJS, ITRON_OBJS, NETWORKING_OBJS.
* 2002-05-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-291-0/+5
| | | | | * configure.ac: Add libnetworking. * wrapup/Makefile.am: Ditto.
* 2002-05-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-281-0/+4
| | | | | * configure.ac: Add libblock. Add libfs. Add AM_CONDITIONAL(UNIX). * wrapup/Makefile.am: Add libblock, libfs/dosfs, libfs/imfs.
* 2002-05-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-171-0/+2
| | | | | * configure.ac: Add libcsupport. * wrapup/Makefile.am: Ditto.
* 2002-04-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-161-1/+0
| | | | * configure.ac: Remove ENABLE_GCC28.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-2/+2
| | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-01-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-161-3/+10
| | | | | | | | | * Makefile.am: Apply @subdirs. Remove POSIX_SUBDIRS. Remove ITRON_SUBDIRS. * configure.ac: Rework enable_unixlib handling. Add RTEMS_MULTILIBS to cpuopts.h. * include/Makefile.am: Add rtems/fs.h, rtems/userenv.h. Add $(PROJECT_INCLUDE)/rtems. Remove libio_.h.
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-061-0/+1
| | | | * Makefile.am: Readded reference to wrapup.
* 2002-01-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-041-1/+0
| | | | * Makefile.am, configure.ac: Remove references to wrapup subdirectory.
* 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-24/+28
| | | | | | | | | | | | | | | | * configure.ac: Use AS_IF instead of if/then/else. Add AC_DEFINE_UNQUOTED(RTEMS_UNIX) for RTEMS_CPU==unix. Add AC_DEFINE_UNQUOTED(RTEMS_UNIXLIB) for RTEMS_CPU==unix. Add include/Makefile to CONFIG_FILES. Add AC_ENABLE_MULITLIB. Remove wrapup/rtems, wrapup/itron, wrapup/posix. Remove */optman/Makefile from CONFIG_FILES. * Makefile.am: Add include to SUBDIRS. * rtems/Makefile.am: Remove optman from SUBDIRS. * sapi/Makefile.am: Remove optman from SUBDIRS. * include/Makefile.am: New file. * include/rtems/bspIo.h: Relocated from lib/include. * include/rtems/libio_.h: Relocated from lib/include.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-171-1/+1
| | | | * configure.ac: Use RTEMS_CPU_SUBDIRS to make autoconf-2.52 happy.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-161-18/+2
| | | | | * configure.ac: Use AC_CONFIG_SUBDIRS for posix and itron. Reflect changes to configuration of rtems, score and sapi subdirs.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-111-0/+117
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate.
