path: root/c/src/exec/configure.ac (follow)
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-061-0/+1
| | | | * Makefile.am: Readded reference to wrapup.
* 2002-01-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-041-1/+0
| | | | * Makefile.am, configure.ac: Remove references to wrapup subdirectory.
* 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-24/+28
| | | | | | | | | | | | | | | | * configure.ac: Use AS_IF instead of if/then/else. Add AC_DEFINE_UNQUOTED(RTEMS_UNIX) for RTEMS_CPU==unix. Add AC_DEFINE_UNQUOTED(RTEMS_UNIXLIB) for RTEMS_CPU==unix. Add include/Makefile to CONFIG_FILES. Add AC_ENABLE_MULITLIB. Remove wrapup/rtems, wrapup/itron, wrapup/posix. Remove */optman/Makefile from CONFIG_FILES. * Makefile.am: Add include to SUBDIRS. * rtems/Makefile.am: Remove optman from SUBDIRS. * sapi/Makefile.am: Remove optman from SUBDIRS. * include/Makefile.am: New file. * include/rtems/bspIo.h: Relocated from lib/include. * include/rtems/libio_.h: Relocated from lib/include.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-171-1/+1
| | | | * configure.ac: Use RTEMS_CPU_SUBDIRS to make autoconf-2.52 happy.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-161-18/+2
| | | | | * configure.ac: Use AC_CONFIG_SUBDIRS for posix and itron. Reflect changes to configuration of rtems, score and sapi subdirs.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-111-0/+117
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate.
