* configure.ac, sptests/Makefile.am: Exercise passing as object Id of
SELF.
* sptests/spname01/.cvsignore, sptests/spname01/Makefile.am,
sptests/spname01/ada_spname01.scn, sptests/spname01/spname01.adb,
sptests/spname01/sptest.adb, sptests/spname01/sptest.ads: New files.
* configure.ac, samples/Makefile.am: Added a test for Clock_Get_Uptime
* samples/nsecs/.cvsignore, samples/nsecs/Makefile.am,
samples/nsecs/config.h, samples/nsecs/nsecs.adb,
samples/nsecs/nsecs.scn, samples/nsecs/sptest.adb,
samples/nsecs/sptest.ads: New files.
* configure.ac, samples/base_sp/base_sp.scn, samples/base_sp/config.h,
samples/base_sp/sptest.adb, samples/hello/config.h,
samples/ticker/config.h, samples/ticker/ticker.scn,
sptests/Makefile.am, sptests/sp01/sp01.scn, sptests/sp02/config.h,
sptests/sp02/sp02.scn, sptests/sp03/config.h, sptests/sp03/sp03.scn,
sptests/sp04/sp04.scn, sptests/sp04/sptest.adb,
sptests/sp05/config.h, sptests/sp05/sp05.scn, sptests/sp06/config.h,
sptests/sp07/config.h, sptests/sp07/sp07.scn,
sptests/sp07/sptest.adb, sptests/sp07/sptest.ads,
sptests/sp08/config.h, sptests/sp08/sp08.scn,
sptests/sp09/Makefile.am, sptests/sp09/config.h,
sptests/sp09/sp09.scn, sptests/sp09/sptest.adb,
sptests/sp09/sptest.ads, sptests/sp11/config.h,
sptests/sp11/sp11.scn, sptests/sp12/config.h, sptests/sp12/sp12.scn,
sptests/sp13/config.h, sptests/sp13/sp13.scn,
sptests/sp13/sptest.adb, sptests/sp14/config.h,
sptests/sp14/sp14.scn, sptests/sp15/config.h, sptests/sp15/sp15.scn,
sptests/sp16/config.h, sptests/sp16/sp16.scn,
sptests/sp16/sptest.adb, sptests/sp17/config.h,
sptests/sp19/config.h, sptests/sp19/sp19.scn, sptests/sp20/config.h,
sptests/sp20/sp20.scn, sptests/sp22/config.h, sptests/sp22/sp22.scn,
sptests/sp23/config.h, sptests/sp23/sp23.scn, sptests/sp24/config.h,
sptests/sp24/sp24.scn, sptests/sp25/config.h, sptests/sp25/sp25.scn,
support/init.c, support/test_support.adb, support/test_support.ads,
tmtests/tm09/config.h, tmtests/tm20/tmtest.adb,
tmtests/tmoverhd/dummy_rtems.adb, tmtests/tmoverhd/dummy_rtems.ads,
tmtests/tmoverhd/tmtest.adb, tmtests/tmoverhd/tmtest.ads: Updated
tests so that they would all compile and run without errors. Some
tests that are no longer valid using the current binding were
removed. Also updated the .scn files to reflect the current test
output.
* sptests/sp21/.cvsignore, sptests/sp21/Makefile.am,
sptests/sp21/config.h, sptests/sp21/sp21.adb, sptests/sp21/sp21.scn,
sptests/sp21/sptest.adb, sptests/sp21/sptest.ads,
sptests/spsize/.cvsignore, sptests/spsize/Makefile.am,
sptests/spsize/spsize.adb, sptests/spsize/sptest.adb,
sptests/spsize/sptest.ads: Removed.
* configure.ac: Reflect changes to testsuites/automake,
testsuites/aclocal.
* configure.ac: Add 2nd arg to RTEMS_TOP.
Unconditionally configure MP-directories.
* Makefile.am: Don't include @RTEMS_BSP@.cfg.
Add DIST_SUBDIRS comprising MP-subdirs.
* samples/Makefile.am: Add DIST_SUBDIRS comprising MP-subdirs.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* Makefile.am, configure.ac, samples/Makefile.am: Do not configure
them unless multiprocessing is enabled.
* mptests/Makefile.am: New.
* mptests/mp01/Makefile.am: New.
* mptests/mp01/node1/Makefile.am: New.
* mptests/mp01/node2/Makefile.am: New.
* samples/base_mp/Makefile.am: Comment out building mptest$(EXEEXT).
* samples/base_mp/node1/Makefile.am: New.
* samples/base_mp/node2/Makefile.am: New.
* configure.ac: Add mptests/mp01. Add samples/base_mp.
* sptests/sp09/sptest.adb: Add Result to SCREEN_13.
Remove Status from TASK_1.
* sptests/sp21/sptest.adb: Add Result to TASK_1.
* tmtests/tm20/tmtest.adb: Remove various RETURN_VALUEs.
* ada.am: Remove ADACOMPILE, ADAC. Add AM_LDFLAGS, LDFLAGS.
* configure.ac: Check for m4. Abort if HAS_GNAT = no.
* tm27 and tm27 are irrelevant as Ada binding tests.
* tmtests/tm26/Makefile.am, tmtests/tm26/README, tmtests/tm26/tm26.adb,
tmtests/tm26/tmtest.adb, tmtests/tm26/tmtest.adp,
tmtests/tm26/tmtest.ads, tmtests/tm27/Makefile.am, tmtests/tm27/README,
tmtests/tm27/tm27.adb, tmtests/tm27/tmtest.adb,
tmtests/tm27/tmtest.ads: Removed.
* configure.ac, tmtests/Makefile.am: Modified to reflect above.
* Makefile.am: Activate tmtests.
* configure.ac: Activate tmtests.
* samples/base_mp/Makefile.am: Add nodeX subdirs.
* sptests/sp01/Makefile.am: Add *.scn.
* sptests/sp02/Makefile.am: Add *.scn.
* sptests/sp03/Makefile.am: Add *.scn.
* sptests/sp04/Makefile.am: Add *.scn.
* sptests/sp05/Makefile.am: Add *.scn.
* sptests/sp06/Makefile.am: Add *.scn.
* sptests/sp07/Makefile.am: Add *.scn.
* sptests/sp08/Makefile.am: Add *.scn.
* sptests/sp09/Makefile.am: Add *.scn.
* sptests/sp11/Makefile.am: Add *.scn.
* sptests/sp12/Makefile.am: Add *.scn.
* sptests/sp13/Makefile.am: Add *.scn.
* sptests/sp14/Makefile.am: Add *.scn.
* sptests/sp15/Makefile.am: Add *.scn.
* sptests/sp16/Makefile.am: Add *.scn.
* sptests/sp17/Makefile.am: Add *.scn.
* sptests/sp19/Makefile.am: Add *.scn.
* sptests/sp20/Makefile.am: Add *.scn.
* sptests/sp21/Makefile.am: Add *.scn.
* sptests/sp22/Makefile.am: Add *.scn.
* sptests/sp23/Makefile.am: Add *.scn.
* sptests/sp24/Makefile.am: Add *.scn.
* sptests/sp25/Makefile.am: Add *.scn.
* Makefile.am: New.
* configure.ac: New.
* ada.am: New.
* support/Makefile.am: New.
* samples/Makefile.am: New.
* samples/base_mp/Makefile.am: New.
* samples/base_sp/Makefile.am: New.
* samples/hello/Makefile.am: New.
* samples/ticker/Makefile.am: New.
