Port
+ v850 does not have appear to have any optimized bit scan instructions
+ v850 does have single instructions for wap u16 and u32
+ Code path optimization preferences set
+ Add BSP variants for each GCC CPU model flag and a README
- v850e1 variant does not work (fails during BSP initialization)
BSP for GDB v850 Simulator
+ linkcmds matches defaults in GDB simulator with RTEMS mods
+ crt1.c added from v850 newlib port for __main()
+ BSP exits cleanly
+ printk and console I/O work
+ uses clock tick from IDLE task
+ Tests not requiring real clock ISR work
Documentation
+ CPU Supplment chapter for v850 added
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
for details.
* aclocal/bspopts.m4: Added macros for cache options
RTEMS_BSPOPTS_SET_DATA_CACHE_ENABLED,
RTEMS_BSPOPTS_HELP_DATA_CACHE_ENABLED,
RTEMS_BSPOPTS_SET_INSTRUCTION_CACHE_ENABLED, and
RTEMS_BSPOPTS_HELP_INSTRUCTION_CACHE_ENABLED.
PR 1729/cpukit
* aclocal/check-smp.m4, aclocal/enable-smp.m4: New files.
* aclocal/rtems-top.m4: Add pkgdatadir.
* aclocal/rtems-top.m4, aclocal/version.m4:
Rename RTEMS_API into _RTEMS_API.
* aclocal/canonical-target-name.m4:
Stop pretending no_cpu* was buildable.
Derive RTEMS_CPU from "$host_cpu".
Error out if "$host" doesn't match "*-*-rtems*".
PR 1561/cpukit
* aclocal/rtems-cpu-subdirs.m4: Merge SPARC64 port.
* aclocal/version.m4: Bump RTEMS_API to 4.11.
Bump _RTEMS_VERSION to 4.10.99.0.
* aclocal/bsp-alias.m4: Change quoting to work-round
http://www.freebsd.org/cgi/query-pr.cgi?pr=146378.
* aclocal/bsp-linkcmds.m4: New.
* aclocal/bsp-alias.m4: New.
* configure.ac: Apply RTEMS_BSP_ALIAS for RTEMS_BSP_FAMILY.
* aclocal/env-rtemsbsp.m4: Remove AM_CONDITIONAL MULTILIB.
* configure.ac: Pick up make/custom/*.
* aclocal/check-custom-bsp.m4: Adapt to changes to configure.ac.
* aclocal/canonical-target-name.m4: Remove RTEMS_HOST (unused).
* aclocal/check-custom-bsp.m4: Let _RTEMS_CHECK_CUSTOM_BSP look for
*.cfg into c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom.
* aclocal/bsp-configure.m4: Add RTEMS_BSP_BOOTCARD_OPTIONS.
* aclocal/check-networking.m4: Disable TCP/IP on targets without enough
physical address to support BSD TCP/IP stack.
* aclocal/bsp-bootcard-options.m4: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
now use the same macros.
* aclocal/bsp-bspcleanup-options.m4: New file.
* aclocal/bspopts.m4: Quoting cosmetics.
* aclocal/rtems-cpu-subdirs.m4: Add Lattice Mico32 support.
* src/aclocal/rtems-cpu-subdirs.m4: Add new M32R port. It is just a
beginning but the BSP is functional enough to initialize and shutdown
RTEMS.
* aclocal/rtems-cpu-subdirs.m4: Add new M32C port.
* aclocal/bsp-bootcard-options.m4: Generalize and correct comment.
* aclocal/bsp-bootcard-options.m4: Fix quoting.
* aclocal/bsp-bootcard-options.m4: New file.
* aclocal/bsp-bootcards-handles-ram-allocation.m4: Removed.
* aclocal/version.m4: Bump RTEMS_API to 4.10.
Bump _RTEMS_VERSION to 4.9.99.0.
* aclocal/prog-cc.m4: Add -Wnested-externs.
* aclocal/prog-cc.m4: Add -Wimplicit-function-declaration
-Wstrict-prototypes to RTEMS_CFLAGS.
* aclocal/bsp-bootcards-handles-ram-allocation.m4: New file.
* aclocal/version.m4: Bump RTEMS_API to 4.9.
Bump RTEMS_VERSION to 4.8.99.0.
* configure.ac, wrapup/Makefile.am: Remove RDBG.
* aclocal/check-rdbg.m4, aclocal/enable-rdbg.m4, librdbg/.cvsignore,
librdbg/Makefile.am, librdbg/preinstall.am,
librdbg/include/rdbg/rdbg.h, librdbg/include/rdbg/servrpc.h,
librdbg/include/rdbg/i386/rdbg_f.h, librdbg/include/rdbg/i386/reg.h,
librdbg/include/rdbg/m68k/rdbg_f.h, librdbg/include/rdbg/m68k/reg.h,
librdbg/include/rdbg/powerpc/rdbg_f.h,
librdbg/include/rdbg/powerpc/reg.h, librdbg/src/_servtgt.c,
librdbg/src/awk.svc, librdbg/src/excep.c, librdbg/src/ptrace.c,
librdbg/src/rdbg.c, librdbg/src/remdeb.x, librdbg/src/servbkpt.c,
librdbg/src/servcon.c, librdbg/src/servrpc.c, librdbg/src/servtgt.c,
librdbg/src/servtsp.c, librdbg/src/servutil.c,
librdbg/src/i386/excep_f.c, librdbg/src/i386/rdbg_cpu_asm.S,
librdbg/src/i386/rdbg_f.c, librdbg/src/i386/any/remdeb.h,
librdbg/src/i386/any/remdeb_f.x, librdbg/src/i386/any/remdeb_svc.c,
librdbg/src/i386/any/remdeb_xdr.c, librdbg/src/m68k/excep_f.c,
librdbg/src/m68k/rdbg_cpu_asm.S, librdbg/src/m68k/rdbg_f.c,
librdbg/src/m68k/any/remdeb.h, librdbg/src/m68k/any/remdeb_f.x,
librdbg/src/m68k/any/remdeb_svc.c, librdbg/src/m68k/any/remdeb_xdr.c,
librdbg/src/powerpc/excep_f.c, librdbg/src/powerpc/rdbg_cpu_asm.S,
librdbg/src/powerpc/rdbg_f.c,
librdbg/src/powerpc/new_exception_processing/remdeb.h,
librdbg/src/powerpc/new_exception_processing/remdeb_f.x,
librdbg/src/powerpc/new_exception_processing/remdeb_svc.c,
librdbg/src/powerpc/new_exception_processing/remdeb_xdr.c: Removed.
* aclocal/target.m4: Strip CFLAGS (Hack to prevent bsp-cflags from
being used to compile "tools").
