path: root/c/ACKNOWLEDGEMENTS (follow)
* updated to reflect gen68360 from Eric Norum.Joel Sherrill1996-03-211-0/+4
* SPARC port passes all testsJoel Sherrill1995-10-301-1/+2
* SPARC merged and successfully tested w/o interrupt supportJoel Sherrill1995-10-061-0/+6
* Incorporated the submission from John S. GwynneJoel Sherrill1995-09-191-0/+10
| | | | | | <jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support for interrupt handling and bfffo support, the two BSPs he submitted (efi68k and efi332), and SGI Irix 5.3 host support.
* Merged PowerPC port as submitted by Andy Bray of I-CUBED, LtdJoel Sherrill1995-08-221-0/+7
| | | | | | | | | | (andy@i-cubed.demon.co.uk). This initial submission is known to work on the IBM 403. It is thought to work on the Motorola 601, 603, and 604 although this remains to be tested. Another user -- Doug Currie (e@flavors.com) -- is interested in this work and will be testing it on the 604 using the Metrowerks C compiler and a different format assembly language.
* Ada95, gnat, go32Joel Sherrill1995-07-121-0/+3
* added David Glessner's 68302 work to ACKNOWLEDGEMENTS.Joel Sherrill1995-06-141-0/+6
| | | | updated PROBLEMS to reflect recently reported things.
* Initial revisionJoel Sherrill1995-05-111-0/+51
