* | added Jiri for autoconf'ing | Joel Sherrill | 1997-04-02 | 1 | -0/+3 |
* | added i386ex from Erik Ivanenko | Joel Sherrill | 1996-10-15 | 1 | -0/+3 |
* | added missing word in ACKNOWLEDGEMENTS | Joel Sherrill | 1996-09-20 | 1 | -1/+2 |
* | added AMD 29K port | Joel Sherrill | 1996-09-18 | 1 | -1/+1 |
* | added mvme147s from Dominique le Campion | Joel Sherrill | 1996-09-18 | 1 | -1/+2 |
* | changed to reflect status of R4600 work. | Joel Sherrill | 1996-09-06 | 1 | -1/+1 |
* | added MIPS port by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 1996-09-06 | 1 | -0/+5 |
| | | | | (ostertag@transition.com). | ||||
* | changed joel's email address | Joel Sherrill | 1996-05-24 | 1 | -4/+4 |
* | added acknowledgement for Motorola MVME147 from Dominique le Campion | Joel Sherrill | 1996-05-24 | 1 | -0/+4 |
| | | | | | (Dominique.LECAMPION@enst-bretagne.fr), for Telecom Bretagne and T.N.I. (Brest, France) | ||||
* | updated to reflect gen68360 from Eric Norum. | Joel Sherrill | 1996-03-21 | 1 | -0/+4 |
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 1 | -1/+2 |
* | SPARC merged and successfully tested w/o interrupt support | Joel Sherrill | 1995-10-06 | 1 | -0/+6 |
* | Incorporated the submission from John S. Gwynne | Joel Sherrill | 1995-09-19 | 1 | -0/+10 |
| | | | | | | <jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support for interrupt handling and bfffo support, the two BSPs he submitted (efi68k and efi332), and SGI Irix 5.3 host support. | ||||
* | Merged PowerPC port as submitted by Andy Bray of I-CUBED, Ltd | Joel Sherrill | 1995-08-22 | 1 | -0/+7 |
| | | | | | | | | | | (andy@i-cubed.demon.co.uk). This initial submission is known to work on the IBM 403. It is thought to work on the Motorola 601, 603, and 604 although this remains to be tested. Another user -- Doug Currie (e@flavors.com) -- is interested in this work and will be testing it on the 604 using the Metrowerks C compiler and a different format assembly language. | ||||
* | Ada95, gnat, go32 | Joel Sherrill | 1995-07-12 | 1 | -0/+3 |
* | added David Glessner's 68302 work to ACKNOWLEDGEMENTS. | Joel Sherrill | 1995-06-14 | 1 | -0/+6 |
| | | | | updated PROBLEMS to reflect recently reported things. | ||||
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+51 |
