* | c/ACKNOWLEDGEMENTS: Remove references to code long removed | Joel Sherrill | 2016-01-23 | 1 | -48/+0 |
* | Obsolete and remove powerpc/mbx8xx | Joel Sherrill | 2016-01-23 | 1 | -6/+0 |
| | | | | closes #2545. | ||||
* | Obsolete and remove m68k/ods68302 BSP | Joel Sherrill | 2016-01-23 | 1 | -5/+0 |
| | | | | closes #2544. | ||||
* | Obsolete and remove m68k/gen68302 | Joel Sherrill | 2016-01-23 | 1 | -6/+0 |
| | | | | closes #2543. | ||||
* | Remove H8300 port | Joel Sherrill | 2016-01-04 | 1 | -7/+2 |
| | | | | updates #2452. | ||||
* | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 2012-05-11 | 1 | -4/+0 |
| | | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | ||||
* | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-29 | 1 | -4/+1 |
| | | | | | * MAINTAINERS, README.configure, c/ACKNOWLEDGEMENTS, c/TOOL_TARGETS: i960 obsoleted and all references removed. | ||||
* | 2004-01-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-01-07 | 1 | -7/+4 |
| | | | | | * ACKNOWLEDGEMENTS: Remove efi68k and efi332 references as they are no longer in the tree. | ||||
* | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-26 | 1 | -9/+0 |
| | | | | | * ACKNOWLEDGEMENTS: Obsoleting HP PA-RISC port and removing all references. | ||||
* | Added sim68000 BSP for the BSVC simulator. This BSP includes the | Joel Sherrill | 2000-08-01 | 1 | -2/+4 |
| | | | | | alias simcpu32 that supports the CPU32 simulator in BSVC. At this point, it is still under development. | ||||
* | Port of RTEMS to the ARM processor family by Eric Valette | Joel Sherrill | 2000-07-27 | 1 | -5/+5 |
| | | | | | | <valette@crf.canon.fr> and Emmanuel Raguet <raguet@crf.canon.fr> of Canon CRF - Communication Dept. This port includes a basic BSP that is sufficient to link hello world. | ||||
* | Port of RTEMS to the Texas Instruments C3x/C4x DSP families including | Joel Sherrill | 2000-07-26 | 1 | -0/+4 |
| | | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4. | ||||
* | This is the initial addition of the port of RTEMS to the | Joel Sherrill | 2000-06-29 | 1 | -0/+4 |
| | | | | | | | | | | | | | Hitachi H8 family. This port was done by Philip Quaife <philip@qs.co.nz> of Q Solutions and sponsored by Comnet Technologies Ltd. The port was done based on RTEMS 3.5.1 to a Hitach H8300H. The port was updated to RTEMS 4.5 style Makefiles/configure by Joel Sherrill <joel@OARcorp.com>. While doing this Joel added support for the h8300-rtems to binutils, gcc, newlib, and gdb. NOTE: Philip submitted a BSP for a Hitachi evaluation board which is being merged as a separate entity. | ||||
* | Use John Cotton's more permanent email address. | Joel Sherrill | 2000-06-14 | 1 | -1/+1 |
* | Added Cache Manager and MBX8xx credits. | Joel Sherrill | 2000-06-14 | 1 | -0/+14 |
* | More changes. | Joel Sherrill | 1999-10-28 | 1 | -2/+6 |
* | The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson | Joel Sherrill | 1999-10-27 | 1 | -0/+3 |
| | | | | <mark@ramix.com> of RAMIX. | ||||
* | First attempt at icluding Eric Valette and Emmanuel Raguet. | Joel Sherrill | 1999-10-27 | 1 | -0/+6 |
* | Added Jay Kulpinski (jskulpin@eng01.gdds.com) for mvme2307 BSP submission. | Joel Sherrill | 1999-10-05 | 1 | -0/+6 |
* | Added paragraph for Tony Ambardar (tonya@ece.ubc.ca) submitting | Joel Sherrill | 1999-04-29 | 1 | -0/+5 |
| | | | | | | a BSP for the TS-1325 embedded PC from Technologic Systems (http://www.t-systems.com) and patches to enable software floating-point emulation for x86 targets. | ||||
* | Patch from Jay Monkman <jmonkman@frasca.com> to address minor issues | Joel Sherrill | 1999-03-02 | 1 | -2/+3 |
| | | | | in the eth_comm BSP documentation. | ||||
* | Updated to reflect addition of new BSPs. | Joel Sherrill | 1999-02-18 | 1 | -0/+7 |
* | Updated to reflect Thomas Doerfler (td@imd.m.isar.de) submitting the | Joel Sherrill | 1998-10-01 | 1 | -0/+4 |
| | | | | helas403 BSP. | ||||
* | Removed blank line. | Joel Sherrill | 1998-09-24 | 1 | -1/+0 |
* | Corrected ColdFire port information. | Joel Sherrill | 1998-09-21 | 1 | -2/+4 |
* | Updated to reflect TCP/IP stack transition. | Joel Sherrill | 1998-08-20 | 1 | -1/+3 |
* | Added Rod Barman (rodb@cs.ubc.ca) in credits for ColdFire. | Joel Sherrill | 1998-08-01 | 1 | -1/+2 |
* | Added Geoffroy Montel (g_montel@yahoo.com) for the gen68340 BSP. | Joel Sherrill | 1998-07-06 | 1 | -0/+3 |
* | Added David Fiddes for ColdFire. | Joel Sherrill | 1998-06-25 | 1 | -0/+2 |
* | Added freebsd support from Dario Alcocer <alcocer@connectnet.com>. | Joel Sherrill | 1998-06-18 | 1 | -0/+3 |
* | Added Hitachi SH port info. | Joel Sherrill | 1998-03-20 | 1 | -1/+2 |
* | Added credit for host.cfg stuff from Ralf Corsepius (corsepiu@faw.uni-ulm.de). | Joel Sherrill | 1997-11-29 | 1 | -0/+4 |
* | Added termios submission from Eric Norum and Katsutoshi Shibuya. | Joel Sherrill | 1997-10-21 | 1 | -1/+4 |
* | Katsutoshi Shibuya (shibuya@mxb.meshnet.or.jp)of BU-Denken Co., Ltd. | Joel Sherrill | 1997-08-01 | 1 | -0/+6 |
| | | | | | | | (Sapporo, Japan) submitted the extended console driver for the MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines. This device driver supports four serial ports, cooked IO, and provides a portable base for Zilog 8530 based console drivers. | ||||
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 1 | -0/+5 |
| | | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | ||||
* | added ka9q stack | Joel Sherrill | 1997-05-27 | 1 | -0/+4 |
* | KA9Q stack removed prior to testing for 4.0.0 public release. | Joel Sherrill | 1997-05-23 | 1 | -4/+3 |
* | corrected some email addresses | Joel Sherrill | 1997-04-22 | 1 | -4/+4 |
* | corrected Tony Bennett's email address | Joel Sherrill | 1997-04-22 | 1 | -1/+1 |
* | Updated to reflect Tony Bennett's new email address and the incorporation | Joel Sherrill | 1997-04-16 | 1 | -3/+5 |
| | | | | of the ka9q stack, m68040 fpsp, gen68360_040 bsp submitted by Eric Norum. | ||||
* | Added ka9q tcpip stack and network driver for the gen68360. This effort | Joel Sherrill | 1997-04-09 | 1 | -0/+4 |
| | | | | | | | | | | | | | was done based on the 3.6.0 release and had to be autoconf'ed locally. It is turned on is the bsp enables it and it is not explicitly disabled via the configure option --disable-tcpip. As many warnings as possible were removed locally after the code was merged. Only the gen68360 and mvme136 bsps were compiled this way. The ka9q port and network driver were submitted by Eric Norum (eric@skatter.USask.Ca). The network demo programs are not included in the tree at this point. | ||||
* | added Jiri for autoconf'ing | Joel Sherrill | 1997-04-02 | 1 | -0/+3 |
* | added i386ex from Erik Ivanenko | Joel Sherrill | 1996-10-15 | 1 | -0/+3 |
* | added missing word in ACKNOWLEDGEMENTS | Joel Sherrill | 1996-09-20 | 1 | -1/+2 |
* | added AMD 29K port | Joel Sherrill | 1996-09-18 | 1 | -1/+1 |
* | added mvme147s from Dominique le Campion | Joel Sherrill | 1996-09-18 | 1 | -1/+2 |
* | changed to reflect status of R4600 work. | Joel Sherrill | 1996-09-06 | 1 | -1/+1 |
* | added MIPS port by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 1996-09-06 | 1 | -0/+5 |
| | | | | (ostertag@transition.com). | ||||
* | changed joel's email address | Joel Sherrill | 1996-05-24 | 1 | -4/+4 |
* | added acknowledgement for Motorola MVME147 from Dominique le Campion | Joel Sherrill | 1996-05-24 | 1 | -0/+4 |
| | | | | | (Dominique.LECAMPION@enst-bretagne.fr), for Telecom Bretagne and T.N.I. (Brest, France) |
