* | Updated to reflect Thomas Doerfler (td@imd.m.isar.de) submitting the | Joel Sherrill | 1998-10-01 | 1 | -0/+4 |
| | | | | helas403 BSP. | ||||
* | Removed blank line. | Joel Sherrill | 1998-09-24 | 1 | -1/+0 |
* | Corrected ColdFire port information. | Joel Sherrill | 1998-09-21 | 1 | -2/+4 |
* | Updated to reflect TCP/IP stack transition. | Joel Sherrill | 1998-08-20 | 1 | -1/+3 |
* | Added Rod Barman (rodb@cs.ubc.ca) in credits for ColdFire. | Joel Sherrill | 1998-08-01 | 1 | -1/+2 |
* | Added Geoffroy Montel (g_montel@yahoo.com) for the gen68340 BSP. | Joel Sherrill | 1998-07-06 | 1 | -0/+3 |
* | Added David Fiddes for ColdFire. | Joel Sherrill | 1998-06-25 | 1 | -0/+2 |
* | Added freebsd support from Dario Alcocer <alcocer@connectnet.com>. | Joel Sherrill | 1998-06-18 | 1 | -0/+3 |
* | Added Hitachi SH port info. | Joel Sherrill | 1998-03-20 | 1 | -1/+2 |
* | Added credit for host.cfg stuff from Ralf Corsepius (corsepiu@faw.uni-ulm.de). | Joel Sherrill | 1997-11-29 | 1 | -0/+4 |
* | Added termios submission from Eric Norum and Katsutoshi Shibuya. | Joel Sherrill | 1997-10-21 | 1 | -1/+4 |
* | Katsutoshi Shibuya (shibuya@mxb.meshnet.or.jp)of BU-Denken Co., Ltd. | Joel Sherrill | 1997-08-01 | 1 | -0/+6 |
| | | | | | | | (Sapporo, Japan) submitted the extended console driver for the MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines. This device driver supports four serial ports, cooked IO, and provides a portable base for Zilog 8530 based console drivers. | ||||
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 1 | -0/+5 |
| | | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | ||||
* | added ka9q stack | Joel Sherrill | 1997-05-27 | 1 | -0/+4 |
* | KA9Q stack removed prior to testing for 4.0.0 public release. | Joel Sherrill | 1997-05-23 | 1 | -4/+3 |
* | corrected some email addresses | Joel Sherrill | 1997-04-22 | 1 | -4/+4 |
* | corrected Tony Bennett's email address | Joel Sherrill | 1997-04-22 | 1 | -1/+1 |
* | Updated to reflect Tony Bennett's new email address and the incorporation | Joel Sherrill | 1997-04-16 | 1 | -3/+5 |
| | | | | of the ka9q stack, m68040 fpsp, gen68360_040 bsp submitted by Eric Norum. | ||||
* | Added ka9q tcpip stack and network driver for the gen68360. This effort | Joel Sherrill | 1997-04-09 | 1 | -0/+4 |
| | | | | | | | | | | | | | was done based on the 3.6.0 release and had to be autoconf'ed locally. It is turned on is the bsp enables it and it is not explicitly disabled via the configure option --disable-tcpip. As many warnings as possible were removed locally after the code was merged. Only the gen68360 and mvme136 bsps were compiled this way. The ka9q port and network driver were submitted by Eric Norum (eric@skatter.USask.Ca). The network demo programs are not included in the tree at this point. | ||||
* | added Jiri for autoconf'ing | Joel Sherrill | 1997-04-02 | 1 | -0/+3 |
* | added i386ex from Erik Ivanenko | Joel Sherrill | 1996-10-15 | 1 | -0/+3 |
* | added missing word in ACKNOWLEDGEMENTS | Joel Sherrill | 1996-09-20 | 1 | -1/+2 |
* | added AMD 29K port | Joel Sherrill | 1996-09-18 | 1 | -1/+1 |
* | added mvme147s from Dominique le Campion | Joel Sherrill | 1996-09-18 | 1 | -1/+2 |
* | changed to reflect status of R4600 work. | Joel Sherrill | 1996-09-06 | 1 | -1/+1 |
* | added MIPS port by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 1996-09-06 | 1 | -0/+5 |
| | | | | (ostertag@transition.com). | ||||
* | changed joel's email address | Joel Sherrill | 1996-05-24 | 1 | -4/+4 |
* | added acknowledgement for Motorola MVME147 from Dominique le Campion | Joel Sherrill | 1996-05-24 | 1 | -0/+4 |
| | | | | | (Dominique.LECAMPION@enst-bretagne.fr), for Telecom Bretagne and T.N.I. (Brest, France) | ||||
* | updated to reflect gen68360 from Eric Norum. | Joel Sherrill | 1996-03-21 | 1 | -0/+4 |
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 1 | -1/+2 |
* | SPARC merged and successfully tested w/o interrupt support | Joel Sherrill | 1995-10-06 | 1 | -0/+6 |
* | Incorporated the submission from John S. Gwynne | Joel Sherrill | 1995-09-19 | 1 | -0/+10 |
| | | | | | | <jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support for interrupt handling and bfffo support, the two BSPs he submitted (efi68k and efi332), and SGI Irix 5.3 host support. | ||||
* | Merged PowerPC port as submitted by Andy Bray of I-CUBED, Ltd | Joel Sherrill | 1995-08-22 | 1 | -0/+7 |
| | | | | | | | | | | (andy@i-cubed.demon.co.uk). This initial submission is known to work on the IBM 403. It is thought to work on the Motorola 601, 603, and 604 although this remains to be tested. Another user -- Doug Currie (e@flavors.com) -- is interested in this work and will be testing it on the 604 using the Metrowerks C compiler and a different format assembly language. | ||||
* | Ada95, gnat, go32 | Joel Sherrill | 1995-07-12 | 1 | -0/+3 |
* | added David Glessner's 68302 work to ACKNOWLEDGEMENTS. | Joel Sherrill | 1995-06-14 | 1 | -0/+6 |
| | | | | updated PROBLEMS to reflect recently reported things. | ||||
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+51 |
