Update #3866.
Change the ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX value to be in line
with the workspace entry in ARMV7_CP15_START_DEFAULT_SECTIONS.
Close #4395.
When the PowerPC shared console baud rate starts at anything other than
9600 the termios code will set it to 9600 at the first open.
The "powerpc/shared/console" code has the start-up console value fixed
at 9600 baud. This changes the hard-wired constant "9600" in the code
to the configuration setting "BSP_CONSOLE_BAUD" and adds configuration
support in both the "waf" and the legacy configuration systems.
Note that the VME BSPs beatnik, mvme3100, and mve5100 can be improved
by adding a "mvmexxxx" BSP family. This configuration change, as well
as future configuration changes, could then be made in a "grp.yml" file.
Uses configured millisecond per ticks
Refactored the i2c driver to parse register values from the device
tree rather than hardcoding them. But still the clocks have to
initialized manually.
Set the Main Stack Pointer (MSP) to the ISR stack area end just in case
we run using the Process Stack Pointer (PSP). This helps if
applications are started by a boot loader.
This now uses rtems_clock_get_uptime_nanoseconds
to calculate the uptime ticks in milliseconds.
Constantly reinitializing the Cadence UART on every character output
causes data corruption/loss on some ZynqMP hardware. Only initialize
the UART once for early output and give it a kick on startup.
enabled/disabled
CID 1399752: Unused value in disp_hcms29xx_update_task().
Closes #4342
Update #3850
Update #4372
Update #4372
Closes #4321
Updates #4321
- Fixes failure of test smpclock01
The following files have been ported
1) ti_pinmux.c
2) ti_pinmux.h
3) am335x_scm_padconf.c
4) am335x_scm_padconf.h
Update #3784
Detects the SOC type using FDT and also replaces the ti_cpuid.h
header in FreeBSD with custom one.
This patch imports the beagle pinmux driver from FreeBSD into
RTEMS. Previously this driver was placed in RTEMS-libBSD but
this caused double initialization of few pins once during RTEMS
initialization and second time during libBSD initialization.
The following patches port the driver from FreeBSD to RTEMS and
will remove the driver from RTEMS-libBSD.
RTEMS Ticket Update: #3784
FreeBSD head: ca12b7e9534b10af022fed60c043984dbaf4003d
The following files have been imported from FreeBSD:
1) freebsd/sys/arm/ti/am335x/am335x_scm_padconf.h
2) freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
3) freebsd/sys/arm/ti/ti_pinmux.h
4) freebsd/sys/arm/ti/ti_pinmux.c
This patch extends the RTEMS OFW API by adding
rtems_ofw_find_device_by_compat
This function checks if a node has the expected compatible
property.
Makes it simpler to access the QTMR in an application via a FDT name or
link in an application specific FDT entry.
Not used by the driver itself, but shuold be correct if used by
application.
Allows user to set SpaceWire run clock divisor for an individual port.
Without this smp05 and smpthreadlife01 tests may fail
depending on how the boot loader initialized the GPTIMER.
Before the time counter stopped counting when reaching
zero, but tests could work since it could take 2^32 us
before stopping.
The timer driver will potentially overwrite this, but it
happens later due to the initialization order having
RTEMS_SYSINIT_CPU_COUNTER very early.
Moves drvmgr_drivers[] from amba.c to a separate file in order
to avoid the dependecy on APBUART/GPTIMER drivers. This has
an effect when user configured not to use timer or uart
in their project.
The descriptor table size is equal to its alignment and set when
configuring the HW IP through VHDL generics. This SW patch simply
probes the HW how large the RX/TX descriptor tables are and adjusts
accordingly.
The number of descriptors actual used are controlled by other
settings (rxDescs and txDescs) controlled by the user.
Close #4324.
Update #4324.
The new GRCAN_FD IP supports CAN FD standard and is mostly backwards
compatible with GRCAN SW interface. The GRCAN driver have been extended
to support the GRCANFD IP using the same driver.
Additional functions have been added that uses a new CAN FD frame
format and read/write/baud-rate functions that supports both GRCANFD
and GRCAN. To keep the SW API fully backwards compatible with GRCAN,
the old functions remain.
Update #4324.
Update #4324.
Close #4323.
Update #4323.
Reimplemented the baud-rate algorithm from scratch to cope with
GRCAN, GRCANFD and OC_CAN devices.
Update #4323.
When the DMA table has been allocated dynamically, the IOCTL_SET_PACKETSIZE
will trigger an issue where pDev->rx and pDev->tx are not updated with
the new DMA tables base address. Instead the old pointers are used.
There is no point in reallocting the DMA tables because there is no
configuration option to it. Therefore the DMA tables allocation is
moved to a separate function never called from SET_PACKETSIZE.
This is enables the updated codec for GR740 and is backwards compatible
with all other versions of the IP.
Closes #4320
Updates #4320
CID 1437613: Unused value in grcan_set_filter().
This fix was recommended by Daniel Hellstrom (daniel@gaisler.com).
Closes #4301
